Diy : Battery Monitor Led Bars
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
This simple circuit makes it posible to monitor the charging process to a higher level.
Final adjustsments are simple and the only thing needed is a digital voltmeter for the necessary accuracy.
Connect an input voltage of 12.65 volt between the positive and negative poles and adjust the 10K trimmer potentiometer until Led 10 lights up. Lower the voltage and in sequence all other Led's will light up. Check that Led 1 lights up at approximately 11.89 volts.
At 12.65 volt and higher the battery is fully charged, and at 11.89 is considered 'empty'.
The green Led's indicate that the battery capacity is more than 50%, the yellow Led's indicate a capacity of 30% - 50% and the red Led's less that 30%. This circuit, with the components shown, uses less than 10mA.
Ofcourse you can adapt this circuit to your own needs by making small modifications. The circuits above is set for 'DOT' mode, meaning only one Led at a time will be lit. If you wish to use the 'BAR' mode, then connect pin 9 to ground, but obviously with increased current consumption.
The LED brightness can be adjusted up- or down by choosing a different value for the 4K7 resistor connected at pin 6/7
You can also change the to monitoring voltage level. For example, let's say you wanted to change to 10 - 13 volt, you connect 13volt to the input (+ and -) and adjust the 10K potentiometer until Led 10 lights up. Change temporarily the resistors at pin 4 with a 200 Kilo-ohm potentiometer and reconnect a voltage from 10 Volt to the input. Now, re-adjust the 200K potentiometer until Led 1 lights up. When you are satisfied with the adjustment, feel free to exchange the 200K potentiometer with resistors again.(after measuring the resistance from the pot, obviously).
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
haiya... :P don't lah.. this is self proclaim only..
DARKWiNG
22
see dis one cukup oledi!
eclips3
203
Kuala lumpur
hey john, do u have a website where u can post all ur DIY stuffs.
quite interesting.
maybe u can sell it in the future. u know. contributers to a magazine ke or something. i am not kidding here.
narx
1,005
wah lan.... really not bad.. how come i didn`t see it that day?
or new creation?
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
HI narx.
The circuit is completed.. But it is unused because I dunno where to mount it... Will install it in my car after I get the A-Pillar for my Boost Meters, then I will install it ON my A-Pillar.
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
quite interesting.
HI..
Yes I have that idea in mind.. wanted to do so.. But then :
- Time (Need time to archieve all the work, pictures, steps...)
- Money (Webspace.. domain)
- More time (To maintain and answer mails from visitors...)
Still.. for the time being.. forum is easiest.
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
Originally posted by sakuragi+Nov 27 2003, 10:41 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (sakuragi @ Nov 27 2003, 10:41 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-simplythebest@Nov 24 2003, 05:16 PM
Johnsonlam ZTH DIY KING :lol:
And we're glad to have him here [/b][/quote]
Thank you.. thank you ... !!
b11boy
11
Ok ok got it liao... but i don't have the electronics knowledge at all, will ask my friend to have a look on it...
thanks. :D
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
Originally posted by ReNo@Feb 29 2004, 05:19 AM
bro. john still did'nt see the picture la....
Hmm.. maybe the host site is down.. :(
Aiya.. I diden backup the circuit..
I will try to find for another site.
