I go higher on 2 and 3rd gears as my cut off is now is 7000RPM.
I am getting quite used to the soft suspension, for example on corners like Turn 5 & 6 in SIC, you could feel the rear squat to the right and feel the rear lose grip slightly and then in Turn 6, it swaps to the left and again lose traction. Quite fun compared to a coil over set up. But ultimately you will have a lower cornering speed as there is so much body movement.
---------- Post added at 12:20 PM ---------- 6 hour anti-bump limit - Previous post was at 12:17 PM ----------
Thank you Proton, 2nd service, Disc Rotors change plus brake pad, Replace crack front windscreen plus 10K Kms service. All this for RM9. Mitsubishi Lancer owners, eat your heart out!
