Aircon Not Cool When Stationary
ZephyRed
419
3,016
Sunway
any of u guys encounter such prob? where your aircon doesn't seems to be cold when the car's stationary.. but when the car's moving.. itz darn cold like fridge?
any idea whatz the prob? cannot be run out of gas ah.. coz if out of gas.. it wouldn't be cold when the car's moving.
tykiasu
602
Johor Bahru
i had the same problem too... eh...anyone with such experience? when car move or accelerate then cold. :blink:
Zeroed
1,706
45
The fan not working maybe? When the engine is off, plug in the keys and turn on the aircon... you should hear a fan in the engine blowing, if there isnt then take out the fan and whack it with stoplock.
wannabe
1,982
If you are talking abt proton, then i understand your situation. Proton car comes either with denso or paco aircond. For those denso wan shouldnt have this problem but if paco wan then memang like that wan. Same wif my car oso , ask mechanic said " This wan not denso, like this wan , if wan cold when not moving , chnage to denso la "......... but if u r talking abt other than proton then it's out of my league.
acbc
4,615
KD
Z,
I know why... condenser coil dirty or leaking or fan has failed.
In my case, fan wire melted - aircon hot during traffic jams but cold when moving. After fix, condenser coil leaked - hot when outside is hot n vice versa.
tykiasu
602
Johor Bahru
kancil here... Checked the Fan, its working.... and the compressor just chan :( ged!
kayef
39
3,008
i had the same problem also....change the compressor also still the same then went to a different place and they change the valve for me and now no probem.....cold anytime
civic1533
851
from my experience its the fan motor where when the car move the air from front help to cool the condenser but when in a stop the fan cant cool the condenser. so thats why the air con gets hot. the fan is still working but just not good enough. thats the sign that the motor going to KAPUT already. so better save some money for it. :)
evan2000
363
HMMMM...KANCIL well, kancil compressor small mah....and the "radiator" also small mah....so when moving, it got more air flow....it will cool down, while stationary, no air flow...then hot loh...
Solution, maybe add another fan to blow the radiator... last time my kancil also like that...
lumghini
419
JB
members.cardomain.com
i oso think its the problem wit the fan lehz...
Keng
278
5
yeap, most probably is fan....try 2 check if ur fan is running or not... if its running, then send ur car 2 workshop...
Combustion
24
Yes, a car electrical person once told me when move cold, when idle not cold, MOST PROBABLY fan is not powerful enough.
tykiasu
602
Johor Bahru
hi kayef,
Which part of the air cond valve?
Kurt
203
what about got something like smoke coming out from the air cond??? its like breeze.. but then aircond also not very cold...
kayef
39
3,008
Originally posted by tykiasu+May 16 2004, 11:38 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (tykiasu @ May 16 2004, 11:38 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-kayef@May 15 2004, 02:24 AM
hi kayef,
Which part of the air cond valve? [/b][/quote]
i not sure which part la.....when i change that time for my wira the guy only say change the valve......i guess its the whole thing gua.....but mine i did for around 160 la.....
Hi all sifus :adore:
Need help, appriciate for every reply and answer, when the car moving it sounds like 'wruk wruk wruk' the faster i go the faster it produce the noise.
One of my trusted mechanic said sounds like this is only will produce by wheel bearing, but after i've replace it and those noise still appear.
This noise usually happens after i've went thru a rough/bumpy road & rainy/cold weather days.
My question is, except wheel bearing what else is spinning in our car while we...
