Basically can open the header and check the piston and cylinder wall. If cylinder wall still good but piston loose can do ring change. If cylinder wall not good and piston very loose then complete change, means piston and rings and cylinder wall re bore aka Total overhaul.....Actually is there anything that can be done so that old engines dont need to use thicker EO?
Is it Overhaul the engine and change the engine parts to new?
---------- Post added at 11:09 PM ---------- 6 hour anti-bump limit - Previous post was at 11:07 PM ----------
Drive Altis like Jetta, Kelisa like mini cooper, BLM like pocket rocket, Kancil like mira mouse deer, it will be a hard act to follow....Guess that's the reason why cvkit drive uncle speed.
I need to learn to do that I guess...cannot always tekan
