4AFE using 4AGE Auto transmission
turbo10
626
47
3,028
sg petani kedah
I have a friend swapped an auto transmission from 4age into his stock 4afe auto. the problem now it won't shift from 1st into other gears if put in D or any other position. Is there any mod can be done to make it run back normal again? Thank you.
Mr.Chaser
4,065
184
Johor
Bro, swap back to original 4AFE auto gerbox is the only solution, unless u upgraded ur current ECU to Import model... If I'm not wrong, 4age auto gearbox included a socket to plug in for MANU or POWER shif. Local spec none.(Local using mechanical system yet import controlled by ECU)
Mr.Chaser
4,065
184
Johor
alrite then...thanks and appreciate you bro for the info..i'll inform my friend bout this.
U r most welcome, anything u may call 0125300063 for Ivan, he more expert in AE series. Maybe u can check with all other ZTH sifu too,a lot of them very experience!!!:wavey:
Honda Malaysia had just set new benchmarks for executive sedans with the unveiling of the new Accord today. The 9<sup>th</sup> generation Accord now comes in strategic packages, in an effort to offer value while maintaining premium features in all its variants...
