Discussion On Your Daily Ride
sweelt
Nov 6, 2016
2,306
248
If it is your own car that you have driven for years, familiarizing it shouldn't be a problem. If it is different car that you have barely driven in it, then yes, I agree with you.
Yes, any car. First drive is familiarize. Test throttle, brake... etc.
I don expect to redline my wira when first drive after complete swap. Mechanics will f**k me upside down. Hahaha ha.....
RENESIS VIII
7,063
950
Ipoh
I don't even dare to redline any cars until I have driven it several times. Need to familiarize on how the power delivery is and also to make sure how does the engine respond to revving, whether can it rev up easily or does it struggle.
14' no real good choice, all low end tires only! Maybe just Michelin XM2? Or the Yokohama Blue Earth got or not below 15'? Change rims la to 15, then can use 195/55/15 and have quite many choices of UHP tires. Wira PCD is same like Lancer CB 4x 114.3 isn't it?
Toyo R888R cannot use for daily, almost like slick so will easily slip in the wet!
XM2 also entry level only, same as Bluearth AE-01. Did tell him change to 15" then got performance tyres.
Wira PCD 4 x 100, Old Saga is 4 x 114.3
RENESIS VIII
7,063
950
Ipoh
Just want to look for mid range tyres is enough, so no need to change to 15' for now. :biggrin:
ixeo
4,788
3,080
KL, Malaysia
Pilot Preceda even older, the later one was the PP2, then replaced by PS3
PP2 stop production already. it was the only performance choice for 14"... now left Kumho lo, if still can find for 14"..KU31.
RENESIS VIII
7,063
950
Ipoh
Mid range also don't have. Entry and Eco level category.....lol
C-Drive 2 is like the last of its kind already. Maybe I might go for BF Goodrich if the price is right. Try it out on Saga first because that one needs to change tyres soon.
Renesis fast fast, later when u move to 15 inch no more performance tyre dy.
Like this just stay 14. Remain old school size that is popular during 80s and 90s.
If 15 no more performance, you also need to upgrade to 16".
sweelt
Nov 6, 2016
2,306
248
Used 16" wheels not cheap.. :hmmmm:
All moving up to 15" already. 14" last time had PP2, AD-07, C-Drive 2 also.....lol
BF Goodrich used to be quite good, when they had the G-Force Comp model, now only the Advantage T/A model which is normal range only. They are not pushing hard on BR Goodrich now and they are owned by Michelin as second brand, like Viking to Conti, Kelly to Goodyear, Dayton to Bridgestone...
RENESIS VIII
7,063
950
Ipoh
If 15" performance tyres are phased out, then you need to retire already. :rofl:
Now is like you said, either entry or high end semi slick.
Produced by Michelin, I suppose the quality is comparable with Michelin tyres like XM2? If we are comparing BF Goodrich with Viking, Kelly and Dayton, BF Goodrich sounds more like a reputable brand although they are not well known here.
Bro, sweelt will bo 17" loh.....hhahhahah
That is why need just to shift 1" up to 15".....:driver:
Is not about the brand, but the tyre model. BFG was selling the G-Force Comp T/A, that was performance range but now they bring in Advantage T/A only which is lower end. If you can get G Force Comp T/A by all means use, this one good feedback.:biggrin:
RENESIS VIII
7,063
950
Ipoh
If lets say lower end model from different brands are being compared together, wouldn't those from more reputable brands fared better like maybe for example, Viking CT5 VS Michelin XM2?
The news of the new 2008 Mercedes C63 AMG Estate leaked before the launch in the upcoming Frankfurt motor show. It has the outlook of a spacious Mercedes C class wagon but under the hood it features a 6.2 litre V8 engine. Powered by 457bhp and 600Nm, the C63 sprints to 100 km/h in just 4.6 seconds, on par with the C63 sedan at 4.5 seconds. This car also reaches a top...
