Petrol splash back when refilling, Proton Saga 1st gen
RigerZ
Nov 19, 2012
16
503
Subang
So when I pumped petrol just now, I left the nozzle to pump automatically. When it stopped quite a lot of petrol splashed out from the filler hole.
1) I went to a petrol station which I dont normally go to; this is the first time happening. Petrol pumping too fast?
2) I noticed when looking down the filler hole there is a passage at the side where petrol will flow out and go back down the tank. What is this for?
3) I was refilling from 2/5 level. Some forums suggested an air pocket was forcing its way out?
1) Flow was fast and the cut off was slow, probably due to the pump adjustment. However when pumping petrol best not to leave it unattended. You will never know when the pump can fail. I had at one time the pump did not cut so petrol was still flowing but luckily I was holding it
2) As far as i know the side passage is for air flow out when petrol goes in the main passage. When really full you can see even the petrol comes out from there but goes down the main passage again.
3) whether empty, 2/5 or near full no difference...
leinnz
333
57
3,028
Is it from a shell station? mine only happen on shell stations pumps.
joethurr
653
41
Faced the same issue a few times before. Shell stations as well. The cut off was definitely a little delayed, and as you remove the nozzle, quite a bit of petrol tends to spill out. Found this to only happen when filling 'full', If just stick to the RM50 per fill and gauge more accurately it never happens.
A couple of months ago, Ferrari claimed the throne as the fastest around the Nurburgring when the Ferrari 599XX broke the 7-minute barrier. But now, the Italian overlords will have to relinquish their position as the fastest at the 'Ring to another Italian supercar maestro that arguably builds even sexier supercars.
Pagani now lays claim to the title after its Zonda R pipped the 599XX to the finish line by an...
