emanage tuning and installation
luorenzo
Aug 14, 2010
21
7
503
sabah
Greetings to all expertise there, im currently using a stock 4g92 sohc... does this engine have the potential to increase hp if i put e manage ? my engine had slight mod example like exhaust 4-2-1 and larger piping,some power plug cable and a fuel regulator. Any expert there bcz i plan to put in an emanage package . ?? any sifu ? :( seriously very hunger for hp now...probably i will put an adjustable cam pulley...
Battousai
699
3,018
www.durifto.blogspot.com
A quick E-manage question...
If I want to test reverting my car back to stock ECU mapping, can I just unplug the E-manage blue from its wiring harness? Will there be any ill-effects from this?
The car is all stock except for air filter and exhaust.
BLaCkHoWLiNG
'(^^)|Most Awesome Member
8,648
1,349
www.autojunctions.com
long time no c bro... go general talk got a topic for us old kakis ;)
TheSquee
448
12
advice needed.
buying an emanage what is suppose to be in the package
what is an optional and important purchase for tuning purposes ( b16a )
where is the cheapest right now as i wanna do installation at my own shop..
besides emanage what is a good option ?
endy7527
Feb 26, 2011
14
Hi all.. I got check engine lite on my meter, after checking all my sensors ( o2, etc) eveything ok.. Then i disconnect -ve trminal of the batery, n connect it back after 30nd, the check lite is gone.. Is it mean my emanage got reset too?
TheSquee
448
12
advice needed.
where can i get it cheap ?
Shinjite
864
120
Klang
Wanna ask, if E-Manage already tuned and I need to change my car's battery
Does disconnecting the battery resets the tuning done in the E-Manage?
AD_EG
6,328
231
Ipoh
its the same.
u alr got blue wanna change to em-con?
if you wanna copy another cars setting to your mcon is not advisable bro...every car not same tuning.
Samuel Takumi
178
JB
www.voltzers.rules.it
its the same.
so the blue version is same with em-con but i saw the blue version can tune outside the console there but em-con cannot
nop, i just wanna get 1 but i saw lot blue version like imitation 1 so i would like to get em-con
so can use the e-manage software to tune the em-con?
if the engine is same model and same spec can use back the setting of that car?
speed2horizon
2,798
334
1,683
You can even tune the emcon with a emb software. Same engine same spec, different condition as in bore wear n tear, carbon accumulation affecting compression ratio. But just pray that ur engine will last for saving over RM250-RM300. Good luck..
Sil80-13
1,215
44
1,648
If my car stock ECU & now the A/F is 14.7, if I install the E-Manage Blue or any piggyback & tuner set it to 12.5 A/F.
My question is:-
Will the stock ECU will control & back the A/F to 14.7 even after tuner set the A/F to 12.5? What I mean is the A/F setting will back to stock even with piggyback ECU???
Or once we set the A/F with piggyback, theh A/F will remain 12.5 all the time. Need advice as I heard from others that the stock ECU tends to go back the stock A/F even after we install the piggyback ECU...
since there are so many replica or fake fuel regulator selling at RM1xx on the market..anyone have any experience on them?
pls give your feedback on these regulator if u have used them....
thanks
