DIY - Voltage Stabilizer (Electronic Schematics)
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
Those will just act as battery conditioners. Useless in terms of performance.
You want something interesting let me chase my friend to hurry up with the new VS. My one and only was sold to Yewly and is in his Almera.
Simply throwing in caps will just act as one big capacitor and probably just extend battery life at most. If you start playing with frequency and adjusting the caps to suit those frequencies, that's when things start to get interesting.
I really wanna do a review on this.
If he lazy, ask him to give us the schematics. :biggrin:
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
Yeah.. Izso, please do an in depth review on these if possible.
I looked deeply into ECU Mappings, especially those in the Lancer and the Evos (Inspira included), I found out that there are AFR, Ignition and even Spark frequency that are impacted by both the Alternator Voltage and Battery voltage...
Which theoretically means, the more stable your car's internal electrical are, the better performance you will get from the engine... This is true to Electronically Timed engines and newer ECUs... not sure about it generally.
punk
360
76
Negeri Sembilan
This VS does smoothen the voltage but before it reach the load most probably already got interfered by high frequency spark plug.:biggrin:
Correct me if i'm wrong.
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
For 4B1x ECUs (Lancer, Inspira, EvoX), the the look of the Mapping itself, The commanded fuel injector frequency and spark plug logics are based on Alternator voltage. Should not be interfered by any noise or emp of any sort I think.
So the more stable the circuit is, the better the injectors and plug works from this standpoint.
punk
360
76
Negeri Sembilan
ya, because u look from the ecu.
The engineer already design for Electronics compability for every device inside the car.
I'm refering from the battery u put the capacitor.
Have you seen the alternator cable that I reviewed?
Tips for oId cars and electrical power.
I get a pretty constant 13.6v. I suspect this'll benefit your cars more than the VS
Rleo6965
161
46
Philippines
It's easier to eliminate car electrical noise and voltage drop by installing Big 3 Grounding. The whole car electrical system will benefit.
Installing a VS was only to suppress the electrical noise. But voltage drop still exist and causing dim headlights,weak ignition coil voltage etc.
For a company that only had a single core model in its lineup, one that’s based on a design from more than half a century ago, Caterham has done itself well to stay in the black and keep making light, fuss-free and fun to drive machines.
However, they have recently expanded their lineup with the more track-focused SP/300.R that has the likes...
