This is my 1st time DIY installations the grounding cables on kancil. Welcome all sifus give comments. Did my grounding cables connect wrongly ?? Thanks for comments. :)
This is the VS + groundings bought from hamsap.
Inside the box, items very nice looking.
Wrap the VS unit with superlon.
Tight it with cable tights.
Done.
Located VS unit at somewhere far away from engine bay. Avoid heat is the best.
After connected VS cables correctly, green LED should be ON.
Follow by installs all the 5 grounding cables (Firewall, distributors, engine head, air-con, firewall near headlamp).
The grounding cables connector.
All grounding cables connected.
Another view.
All done, tested. Engine rev smoother during low rpm, headlamp brighter.
Nice products i can say. B)
Done.
Another view.
