wanna know the name of it
sam04563
Nov 26, 2013
18
just wanna ask what the name of this part..as the foreman claims that it has some problem.. i wish to do some research on this part..
That specific part is the butterfly controller part. But usually if that's broken its easier to just replace the throttle body
twistedichc
Jan 22, 2013
2,930
255
683
Ampang Point
all i know is that it's connected from pedal to tb where it controls the butterfly, the only problem that i can think of is the spring has gone stiff maybe. even in wiki it doesn't state the name, it's just state "On many cars, the accelerator pedal motion is communicated via the throttle cable, to activate the throttle linkages, which move the throttle plate"
Parts 52 & 54
sam04563
18
any idea bout the price range to replace a whole TB?
---------- Post added at 04:53 PM ---------- 6 hour anti-bump limit - Previous post was at 04:52 PM ----------
Parts 52 & 54
useful info..mind to share the link?
desmond0318
467
48
speed up no problem..after speeding..engine sound like gonna off...the person claims that is TB problem..(sorry for the poor explanation)
Have you ever service TB? Is recommend to do it, and is good to try a cheap way before going for the expansive TB.. Is the way that workshop want extra earn, but dosen't consider scam/con :biggrin:
sam04563
18
what do you mean by service?some sort like cleaning?
means we cn do it by our own?or recommend to ask workshop to do it?
Since your mechanic ask to change the TB looks like you need to find another mechanic to clean it, since the first one might not do it.
I did not have the tools initially. Recently got them and did for my spare old car with 180k km on it.
Before
After
Before
After
Use CRC brand Throttle Body Cleaner
Meaning once you lift off your accelerator the idling starts to drop below 800rpm and feels like wants to die off? If yes I think your TB is just dirty. It doesn't look like a modified TB or anything (unless you did some porting and polishing inside the TB) so you probably only need a clean.
hv no confident to it by own..haha
If that's a Wira, it's fool proof. You can't screw anything up.
- Disconnect the sensor on the rubber air intake first.
- Using a size 10 wrench or socket, loosen the clamp holding the rubber intake connected to your TB.
- Using throttle body cleaner (I recommend CRC brand - about RM15 a bottle), just spray onto the now exposed TB mouth. Using your hand, turn the butterfly open to expose the inside portion of the TB and spray that too.
If you like, use a piece of cloth to wipe it too. If you spray a lot, just note that initial startup might be a bit hard but just keep cranking and pressing the accelerator to clear off the carbon or TB cleaner residue.
- Once done put everything back including the sensor and you're done.
It's a very simple DIY
sam04563
18
thanks sifu!! you are really pro..that's what I facing. .and the rpm is exactly back to 800 rpm asu mentioned..I think I have to agree with you..clean it..hehe
sam04563
18
Before
After
Before
After
do i have to open throttle body or i just need to clean the butterfly?
Hello guys, I accidentally scratched my dad's 2005 Honda Accord front bumper today against a ridiculously high road kerb (or is it curb?). Well, I gotta admit, it is my fault, my driving is not up to standards.. whatever. The front of the car is too long, and my dad's sitting position is too low, that's why I didn't judge properly.
Anyway, I am here to ask if anyone knows of a product that can remove these scratches??? If I can't remove, can I at least do something to cover up the...
