External Radiator Fan Controller
v1ctorong
122
5,028
Dear All,
I just transplant JDM engine into my car. I found that my engine radiator fan only turn on around 95c (external water temp meter). The default ECU setting are basically made for Japan weather which i think its not mean for Malaysia.
When search for radiator fan controller, i found some selling online but looking for an experience foreman that sell and install the said controller for my car. Hope members here can help.
ehdrian
I Don't Care!
3,310
280
1,683
use the PIVOT Fan controller bro..it works for my 63t, same case like urs, 95C on water temp meter baru the fan jalan..
With pivot fan controller, i set it open at 90C, temp maintain at 90-93C during jam, on highway 88C..
ken yeang
6,617
1,327
Sorry to dampen your spirit, bro.
One Sunway sales rep said to me that PIVOT Fan controller is no longer in production (quite some time already actually). If the unit kong, or to claim warranty, replacement stock would not be possible.
Perhaps PIVOT could last long enuf.....if quality is good
ehdrian
I Don't Care!
3,310
280
1,683
There're still plenty of other brands besides the PIVOT..Nonit worry la bro..
can use those PC fan controller or not?? 12v also rite? :biggrin: :hmmmm:
ehdrian
I Don't Care!
3,310
280
1,683
pc fan?..not sure whether it can withstand the heat from the engine..
v1ctorong
122
5,028
what JDM engine u transplant into ur engine??..
Hi Shywalker , its a YRV Turbo @ K3veT
Hi ehdrian, was looking for PIVOT but ken yeang speak my concern.
thanks, it make sense to me.
lesley...partly kidding..partly make sense :biggrin:
ehdrian..not the fan..but the controller..
example: G-VANS 30W - 4 Channel Aluminum Rheobus w/ Multi Color Backlit LED - Version 3 Ultra Voltage Edition - Black (GV2FC-5) - FrozenCPU.com
check out the spec. voltage :smokin:
for someone who prefer manual toggle switch but dunnow where to get one....
Lamptron Hummer 5 Port Military Switch Baybus - Black - FrozenCPU.com
:thrasher:
haha, i have PC fan controller too...but where to feed in the water temp sensor...hehehe.
victor....thats have to ask pc expert lorr.... i just giving some alternative thinking only :adore:
v1ctorong
122
5,028
I see, i think lets eliminate this as i am looking for pure Automotive solution...:burnout:
---------- Post added at 03:49 PM ---------- 6 hour anti-bump limit - Previous post was at 03:46 PM ----------
Bro, may i ask where did you installed your fan controller?
ehdrian
I Don't Care!
3,310
280
1,683
Bro, may i ask where did you installed your fan controller?[/QUOTE]
i'm from penang actually, bought a used pivot f/c, got it installed and been using it for more than half year..no prob also..
A fren of mine driving myvi yrv turbo, bought a new set of pivot f/c from N1 racing because he's having the same prob like u..he's using alum rad also, now he got himself a low temp thermostat from D-Sport, prob settled..
v1ctorong
122
5,028
ok more direct solution that i found... :adore:
Drift performance radiator fan controller - Car Accessories & Parts for sale Selangor - Mudah.my
if not mistaken the seller also a registered seller in zth...
Saw this as well, thanks for pointing out.
Thank you for enlighten me. So the low temp thermostat need to in my shopping list now. Also thank you to recommend the shop to me.
In order to benefit forumer, i will include the my experience in another topic created, after installation.
my air cond is working fine til just now the air cond pump just cut off and would not turn on....i suspect ither the pump switch or the fuse or relay is blown.. but i don know is there a fuse or relay for the air cond pump?? pls help!!!
