External Radiator Fan Controller
ehdrian
I Don't Care!
3,310
280
1,683
Penang
Thank you for enlighten me. So the low temp thermostat need to in my shopping list now. Also thank you to recommend the shop to me.
In order to benefit forumer, i will include the my experience in another topic created, after installation.[/QUOTE]
No prob bro, sharing is caring after all.
You can try installing Pivot f/c first, if it solves yr prob then u dun hv to waste money ade.
If it doesnt then only proceed with lower temp thermostat and alum radiator.
Yeah, share the before and after pivot f/c result with us.
v1ctorong
122
38
5,028
Your suggestion is valid but i knew that my radiator is under perform. Where water temp wun drop when i on aircond during traffic jam under the hot afternoon sun. Both Fan and radiator need to change as the engine is now producing 3x more heat than the original kelisa engine :D. So will only consider to change low temp thermostat if condition wun improve.
Hi,
My friend's new saga has some small bent-ins on the door and he's planning to get it fixed.
The bent-in is only visible under the sun and only after careful examination.
So if he were to bring it to fix, how much will it cost? Or will the workshop advice him not to waste money on such minor stuff?
