my air cond is working fine til just now the air cond pump just cut off and would not turn on....i suspect ither the pump switch or the fuse or relay is blown.. but i don know is there a fuse or relay for the air cond pump?? pls help!!!
I`m a mechanic myself. but this Renault Kangoo is givin me headache! Cold start,ok! But when it has done 5 to 10km, it will suddenly dies off! I had top-overhaul the engine, T.belt replaced, coil replaced,CPU re-set,battery replaced. The temp. gauge shows fine at optimum. At times it will jerks when accelerate. An original fuel pump was also placed. pls help.
