No RPM cut for l5
mag9556
2,770
43
1,648
me just change my EF engine to JB engine and current faced a huge headache that that engine can ramp till 10k also no cut...
anything to make to cut it?:smokin: no cut rpm for me is very good but when my wife use.. die... ramp till masuk longkang....
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
much better.... :biggrin:
err... your using JB wiring or still EF ones?
mag9556
2,770
43
1,648
outside JB wire and inside EF wire...
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
why you didn't use all JB wirings?
I don't know how, but I do note that all electronic cuts in EF and JB engines can be disable if we shorten a few connection....
...maybe the RPM cut connection has been shorten when you hybrid EF wif JB wirings?
mag9556
2,770
43
1,648
me also wanted to use but the JB engine inside wiring been stolen...
actually brought the engine in very cheap price...
thanks for this bro.. got the actual problem already after put back my AFC... the meter problem..
just like playing puzzle.. now my digital speed meter malfunction.. had to check the ECU already... me using JB ECU...
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
haha... gud luck playing puzzle... at least your car is running... my car already benched... leaked engine +turbo issue and no money to repair :banghead:
mag9556
2,770
43
1,648
aiyo.. so bad...what u want to find.. maybe me can find some cheap things for u, coz my fren wanted to sell of a lot of turbine at his shop from ar60 to IHF3...
by the way bro, do you had JB ecu diagram copy? pm me if you got...:smokin:
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
thanks bro for the kind offer... me thinking of looking JB-DET engine wif complete wirings... but then money oso an issue huhuhu
JB ecu diagram? I'm also looking for one hehe
Wilson13B
296
30
Last i DIY a rev cut system for a KE70 with original carburetor engine,coz have Weber dy,the engine rev up over it's redline easy like nobody business as original engine doesn't have rev cut function as it was a 80's technology ma,so i DIY a rev cut system which works perfectly and can tune to the exact rpm u wan't it to cut ~
If u interested to know how to do it,do PM me =)
When I got my new system installed, the installer accidentally drilled the bracket hole for the o2 sensor wrongly, at the lower part of the downpipe there... so he welded a plate at the hole and drilled another.
Now after some driving the downpipe is leaking... there is this loud spshhhhshshhhhhh sound and my idling jumps up and down from 200-1500rpms. I was wondering if its safe to drive like this to my mechanic's shop at around summit USJ area?
Or will the leak do something to my...
