[WTA]B16B Valve Springs
SimonsayZ
155
Puchong
Hi all sifu, Wana ask if B16B valve springs can be used on B16A?
Will it make any difference or must it have to match with B16B cams? :hmmmm:
pencalat
805
19
JB
Sure can!!!!!!!!!!!
If comes with b16b cam oso cun.....
AD_EG
6,000 RPM
6,328
231
Ipoh
Definitely can.....
Like pencalat said....better to match with b16b for more performance....
but even if you use on b16a also can.....
guangek9
8,000 RPM
8,411
8
Can be use but I think cannot feel any power up lor.r Because u still using b16a cam.
SimonsayZ
155
Puchong
Ok thanks all sifu for the info. :adore:
So that means no point even if I use it with stock B16a cams. How much are the B16B cams selling in the market now?
AD_EG
6,000 RPM
6,328
231
Ipoh
Yea...if you're getting it for damn cheap or wat..then buy 1st and keep..no need install..save on labour...until you get the cams...b16b Rm1xxx...
caleb_5375
1,293
14
type R valve spring is double.one big one small spring to make sure ur valve din float on high rev. valve float at high rpm can cause piston to valve impact and ur compression wont be that good on high rev coz the valve is float and din seal properly for the compression stroke.
Kobra
89
1,508
very2 correct la..
EK4 also have dual spring for both side..
guangek9
8,000 RPM
8,411
8
Better u keep the money get the b16b high cam only install together. Don't waste the times and money on the valve spring. Because valve spring very hard to install.
zendengoh
155
KL Kepong
www.zhapalang.com.my
Skunk2 do have all the items u need :wavey:
pencalat
805
19
JB
agreed with u guang.....
Kobra
89
1,508
korek..korek..
i have some information from turbo sifus out there.
1. i need some explanation for turbo different of cars like ford ranger, toyota hilux and other with cars like evos,skyline gtr and others.......
2. can sifu here explain me about the different......
3. i also would like to know how strong does the turbo for that twin cabin compare to those powerful cars........which one is stronger/powerful?
4. can the turbo in twin cabin be as powerful as those evos car?
5. if i want to make the turbo...
