Anyone use Supertech Viton Valve Seal set before?
Sil80-13
1,215
44
1,648
Hi guys,
1. Anyone use Supertech Viton Valve Seal set before for their B series engine? Is it reliable & this product is from where? Japan?
2. And also heard alot that now all the Valve Seal is made from Thailand even with Honda sticker on it. Can this be use?
3. Can we still find original Valve Seal for B series engine?
As I need to change valve seal due to valve seal failure. Any good recommendation?
shiroitenshi
3,676
170
Yes, the new honda stuff I also heard all made in thailand, Most US stuff mostly made in China/Taiwan now, but big companies enforce better QC.
Supertech quite a well known brand, so shouldn't have issues.
The honda valve seals from thailand should work, they're not that complex to screw up IMO.
While you're replacing valve seals, check the valves too, this is a good time as any to replace them. You can choose flat valves, which increases comp about 0.5CR, or retain standard.
Sil80-13
1,215
44
1,648
Thanks for the info bro. Which mean Supertech valve seal is better than those made in Thailand. Right? I mean more reliable...
testpower
403
in my opinion, off course aftermarket parts like supertech is better than oem thailand made parts.
last time i was at taiping also cannot find any shop sell motul. Ipoh only got at the famous falken tyre shop and the zerofour. also notice one shop with motul signboard near the menglembu - falim junction. not sure they got the engine oil or not.
