Wira 1.5 Carburetor Fuel consumption Problem !
Oct 3, 2012
Guys,
Recently i found out my wira 1.5 manual carburetor (1997) is being higher fuel consumption compare to few months ago. its happen so sudden which normally i can get Rm60 - 450km, but now only Rm60 - hardly 400km. Dunno whats wrong with my car, service regularly. Hope you guys here can help me out to solve my problem !
update : get my carburetor tuned and changed spark plug 2 weeks ago, but problem with high FC still there.
Extra question : Everytime i fill up my tyres pressure but then i wish to add in more pressure into my tyres to get better FC, but it keep fail cuz of the pumping machines will automatic cut off and wont let me fill more pressure anymore (got "dit-dit-dit" sound). so guys, how to pump in more pressure ah ?
Guys,
Try servicing the Carburetor, means opening up and wash. Could be dirty after so many years usage.
For higher Tyre pressure, you have to set the pressure you want first then only pump. The dit-dit-dit is when the require pressure is reached, so you just need to set the pressure higher.
wenglucas3
Oh, Is there anything to do with my fuel system ? normally you open fuel cap got "tsssk" sound ? something like releasing pressure / vacuum sound ? i rmb back then my wira got this kinda sound, but after that few months back no more this sound. Since ever the sound gone, my FC starting being bad. is there anything related to my fuel pump ? fuel hose ?
About the tyre thing will try out tonight :)
Yup, sort of pressure built up. If don't have the sound, not sure if the petrol is evaporating or not?
wenglucas3
you meaning petrol evaporating inside the tank ? then there must be some leaking ? the weird thing is i park my car at parking lot for long time when working, then after work i go to check the floor but nothing and no smells of petrol also. this problem exist i think about 1months already. there's sudden a drop of 50km mileage per tank and that's consider so much for me.
Not that sort of leak. If floor got petrol then the leak is very bad already. What I meant was petrol evaporate, but not likely will evaporate that much. Have you check the petrol cap is tight or not?
wenglucas3
Petrol cap i turn till maximum tight, myself sure turn till tight. got inspect the cap when refueling, no signs of damage or crack, juz signs of yellowish maybe due to old already. The rubber seal at edge abit harden already. its already 3 or 4 times i refuel and test with same driving style, still same result so i can confirm is my mileage drop already. Very weird problem~
Rleo6965
161
46
528
Philippines
I don't know if this will help your FC problem.
Have you check your wheel bearing or brake for stuckup?
hello ,
i need some advice i have a satria 1.6 gearbox (manual)
i would like to install it to my gsr turbo..currently it is auto gearbox...
will i have problems doing this......
if anyone has info please tell me.......
