Yes 8jj & 8.5jj rims. Probably need to change rims if going for square, then its gonna be 8.5jj all round.Can try but again depends on the current handling of the car and driver's preference.
Yours on 8/8.5jj rims, is it? Then use 245 all.
Racing drivers got good skill when catching the car during oversteer so they will always prefer the most responsive/neutral setup. Having use staggered for 5 years and now on square, I think I also like the square better but since I need to use 245/40/18, the sidewall height is only 9.8cm which is a bit too thin profile for my liking so slightly harsher ride than what I'd like to be. If I use staggered, I can use 225/45 at the front and 255/40 at the rear which has 3-4mm taller sidewall hence more comfortable ride. So there's a trade off between the 2 setups, whether I want more neutral handling or more comfort, that's my dilemma with my current 18' size. Probably should've gone with square 18x8.5 or 18x9 so I can just use 255/40 all around, or downsize to 17x8.5 and use 245/45/17 all around hence get the most grip with more neutral balance with still more comfort too.
245/45 R18 is the plan. stock was 225/45 & 255/40. Why don't you go with 245/45 R18?
