who can help me solve it..
fr0z3nwei
21
Yesterday i changed my steering..after i changed, when i turn on the road my sitner cannot auto close..if somebody know how to solve it pls help me..and my car is proton gen 2
jinkl
4,624
376
3,183
hehehe i faced the same thing, u have messed with the boss kit , check on that, its stuck or something is not free
JackWaiKit
262
5
www.friendster.com
dismenle ur seering again, here is a small plasic bose ki.
try to turn the kit to suit ur sitner turn angle so that can reset the posn
mostly direction of the kit is on left
arrowhead
4,621
152
5,163
Damansara/PJ
wow bro i have no idea what u are trying to explain. :confused:
anyway, if u want to do it easy, just bring it to an accesories shop. its only a small problem. its probably u didnt put the steering in the correct direction.
boss kit is the "extension" u use when u change from ur original steering to the sports steering. ori steering has built in boss kits, while sports steering requires an external boss kit.
Hi guys,
Would like to seek expert opinion in the way we usually set our Fuel pressure Regulator.
I have bought Aerospeed Fuel Pressure Regulator which comes with a meter to see the psi. For my Waja, I have felt good with 43 psi. However, at one time after I ported my intake manifold, the pressure ran to 45psi.
Thus, I requested the mechanic to help lower it down to 43psi. He unplugged my vacumn hose and basically the pressure went to 50 and above. Then, from there he lower to...
