yeap. everyone's correct. it's all based on personal pref.
hmm, easily put is
motec = hks v pro + vcam systtem.
errrrr..... i wouldn't really put it that way
you can't really compare an ECU with some thing physical like the V-Cam system
The Motec M800 series can control the valve timing for engines equipped with valve timing (VTEC and whatnot) but on the RB26, you're going to need to physically install the Vcam system (which comes with a seperate controller, so you can use any ECU you like)
In the end, its just an ECU...tuning is more important, as that is what actually makes your car go (or not)
as for what turbine to chuck into that Rb25 of yours? I would recommend a 3037... saw one guy running that in his GT-T... 300+ whp and full boost at 3500 rpm
assuming you're looking for somthing responsive and streetable.
otherwise 'pasang je paling besar, tgk telor cukup besar ke tak'
