Short answer is no.Bro, currently I'm using a Greddy old version type R BOV, if I gonna change my BOV, which is the best product to go for? I prefer those BOV can straight replace my current bOV position without any extra work to do.....
Have a noob question here, is it required for remap my ecu if new BOV installed?
Generally, why would you need to retune it? What has changed? Changing one aftermarket blow-off valve for another?Bro, thank for our reply. Mean no need required any remap on ecru if I change new bov? So what u prefer if my situation happen to u? Actually I suspect my bov is time to go, last month I encounter my car will occasionally stall when come into stop, I had wash my aac valve, is much better but it happen again last week, I start to suspect my bov. Any suggestion from you?
Oh ok, thanks for clarifying. I haven't been following your adventures but it's good you have a list. Fueling system means what exactly?Bro, At 1st I've collect all informations which possible to cause the stalling problem as below:
A)vacuum hose leak
B)aac valve dirty
C)bov
D)TPS sensor
E)fueling system
I been suggested to inspect all this items above from A to E. Until now i had done A and B, no leaking hose and AAC valve had clean too. So the next thing I'll check my BOV, that is the reason I continue to post question here and wish to get some answer from senior~
Bro, some AUS forumer said fueling system clog will cause problem at idling too, maybe fuel filter or injector~ But this is the most expensive thing to do among those item i stated, so i put it at my last inspection. :-)[PIMPIN];4491867 said:Oh ok, thanks for clarifying. I haven't been following your adventures but it's good you have a list. Fueling system means what exactly?
Thanks bro for your suggestion~IMO...australian brand BOV that can be routed back to turbo intake was quite good..providing phsst-woot sound but not overly loud compared to directly vented BOV to atmosphere....
go fast bit or sheep dog i don't really remember.....
*(check mines gtr34 BOV sound in youtube)
Well, it goes with the territory. Want to 'play' car sometimes have to face the problems. Are you doing all of the above with the same mechanic? What's their take on the problem? Do they agree with your list or do they have their own theories?Bro, some AUS forumer said fueling system clog will cause problem at idling too, maybe fuel filter or injector~ But this is the most expensive thing to do among those item i stated, so i put it at my last inspection. :-)
Anyway, thanks for told me no remap is required for change aftermarket BOV to another, Thanks bro~
Bro, if this is a common problem and cannot be solved by all of the skyliner then I'll try to make myself used to live with my car....[PIMPIN];4492127 said:Well, it goes with the territory. Want to 'play' car sometimes have to face the problems. Are you doing all of the above with the same mechanic? What's their take on the problem? Do they agree with your list or do they have their own theories?
