Weird Engine
turbo85
Nov 21, 2010
16
Hi,
I have a 10 year old Toyota Corolla. Have been driving for few years.
Recently, when I drive, the engine keeps dying especially after starting up in the morning. This happens also when the car is idling in the middle of the road such as waiting for traffic light, the engine light will just lit and die off. However, this issue is not so prominent after the engine has warmed up, that is after restarting the engine for few times and driving on the road for sometime.
May I know what are the problems? Could you all please help to troubleshoot for me? Hopefully I will get back my problem-free Corolla again :bawling:
Thanks,
turbo85
reintel
732
30
3,028
Cold start actuator/ sensor need cleaning. Send to workshop for full throttle/ intake clean up.
huakenny
LB Performance
9,126
240
3,163
Kota Kinabalu
what engine you are running? as others said, try clean the tb 1st, check also fuel filter n also spark plug
if after died still can start definately not alternator edi.....if alternator kong, once died...it mean died...can only start via push or jump start
turbo85
16
Thanks for all the feedback. I am using the original engine of Corolla AE111, 4A something. By the way, huakenny, what is tb?
Yea, some ppl also recommend me to change the fuel filter n spark plug first..because they are among the cheapest components that we can try out first.
Some other ppl also think about other causes below, been hearing so many bit and pieces here and there, could you pls help to justify and eliminate? :viking:
1. distributor?
2. "electronic board" near the dashboard?
3. idler solenoid?
4. spark plug?
5. fuel filter?
6. alternator?
7. ECU?
Battery is brand new, starter just refurbished, so these two are quite imopossible.
Thanks
guest
346
20
Kota Kinabalu
if u wanted to buy all of the above items that u stated above,...u might throw some cash to buy each of it...y not pinjam some of the item from your friend first?spark plug and fuel filter can buy first..if the item num 1,2,3,6, and 7 can pinjam yr friend first then confirm know the cause is bcoz of the item the buy lor,,,,,hhehee my opinion la....:driver:
ipul_AE111
32
1,508
hey bro...i suggest u clean up ur TB 1st
ur engine is A/T 4afe right..i've oso kena liow last time with my old 4afe.
cost around RM50 only. hope it can solve ur problem
good luck.. btw TB is trotel body (broken spelling la sorry..)
turbo85
16
Is cleaning tb = overhaul? :rolleyes:
So, the plan goes like this:
First, go for
1. TB cleaning
if fails, go for
2. Change spark plug
if fails, go for
3. Change fuel filter and pray hard :adore:
if fails, go for
4....:bawling:
Hopefully i can solve the car problem within RM100 :dong:
ipul_AE111
32
1,508
First, go for
1. TB cleaning
if fails, go for
if fails, go for
if fails, go for
4....:bawling:
no la, not overhol, juz servis the TB. send to any workshop n ask for servis TB. the foreman will know de. its juz cleaning the intake part using caburator spray. correct me if i'm wrong o all sifu2..
juz know as my expirience.
try it 1st, if fail oso, mayb ur ignition part problem. like distributor or spark plug.
for ur 4th is change to twincam 20 lor :biggrin:
xMika
623
85
Selangor
original engine so its 4A-FE. Try to change your distributor cap.. not that expensive rm100 can get already .. maybe the internal terminals worn out already .. when its cold, the metal terminal still not expand yet and therefore connection gap far abit .. easy to misfire and stall the engine .. when its hot ... vice versa la primary school science .. :)
turbo85
16
I have changed the spark plugs, and apparently the problem is not solved.
Well, the mechanic insists on its the distributor which will cost me around RM400-500 which is way different from xMika estimation at ~RM100. I doubt him a lot :rolleyes:
I asked him to proceed on others parts first like fuel filter and clean TB before conclude to distributor. I dont want to change the unnecessaries.
turbo85
16
Hi all,
latest update. after changing spark plugs, fuel filter and clean TB. the mechanic said my car still suffers the same problem, darn d..
any suggestion what should i do? send to toyota corolla service centre to check again?
rgds, turbo85
Kitos
160
7
TB = throttle body lo
When engine check llight comes on it usually is related to part with sensor. This usually is very easy to fix since the check light will have the error code. Next time when the check light come on then send direct to your workshop to get them determine what's the error code so that will tell you what part actually is causing the problem. However don't quote me that will definetely fix your car issue as they may be other parts that can caused the issue but main thing is fix the part that cause the check light as that will definetely affect your car as it's will be required for your ECU to work on getting your car to drive right. Good luck.
Kitos
160
7
The reason your engine is dying is because it have problem. Check light on is way of showing what issue it have. Don't think you are listening how mechanic does the troubleshooting on engine issue. Unless your car doesn't show any check light then the way of diagnosing would be coming from the description of your problem symptons.
turbo85
16
what is "check light"? the blinking engine light? I have done that before at toyota service centre, but couldnt identify what is the problem
ayathu
116
18
Hi turbo85,
I like to help you, I have own a corolla seg. So can you tell a bit further, how the engine stop, does sputter couple of times like before dying or dies imediately. If it sputter than it means fuel supply but if dies off imediately than its ignition related.
fuel supply can be:
1. dirt in fuel supply or clogged fuel filter
2. ISV clogged (idling stabilizer valve)
3. low fuel pressure due to fuel pump
4. faulty fuel pressure regulator
5. faulty fuel injector
if ignition related than could be
1.faulty ignition key switch
2.engine speed sensor in distributor(depends on model, also can pop up error code when dignosed with engine check lite)
3. ignition coil in distributor
4. ecu
These are somethings that i can think of. good luck.
4.
Kitos
160
7
Did you drive to the workshop after the check light is being erased?
I am not verse with toyota ECU but my honda stored the check light error code so i can retrieve it even after i have the car turned off. It will only be erased after i take out the battery supply.
You can do some reading about it on the link here. The code for the error will be different for different car manufacturer but i am sure it's the same for all type of cars for same manufacturer. Good luck.
Check Engine light, OBD II engine trouble codes
AE101-Wong
4,448
113
sensors giving wrong signals will effect ECU calculation boss..
after done those sensors "check engine" light still on menas ur ecu got problem..
i'm believe sensors are easily can get from chop shop for 4AFE and 4AGE..
During routine radiator coolant top up activity, i found out that my top radiator hose leaked. This call for short trip to car spare part shop. Below steps I did to replace it.
Spare part:
1. 1. Hose radiator up- PN PW823117 (this Part No. for Proton Gen 2)- 1 unit. RM17.00
