URGENT! Gearbox problem
munky
1,967
20
PJ
www.playboy.com
I just changed my clutch, and after changing, the gear is very difficult to change from neutral to any gear when the engine is cold. It was like i didnt press enough of the clutch. I could force it after a few minutes the engine warm up. More like more than 5 minutes. But still difficult. Found out the firewall and clutch pedal welding broke already. So sent to workshop for welding. Problem solved. But after 2 days happen again. Called the mechanic he asked to try change gear oil first and try again.
When the foreman adjust the clutch, he said if he set the clutch to be short, the gear cannot engage. SO he set about half pedal (malay ppl say clutch pendek/panjang). But when the engine is cold, the clutch became short, and after sometime it became long.
Has anyone encountered this problem? Before changing clutch i got no problem.
p/s: bought the car 2nd hand, so previous owner have changed the clutch. And the car was originally an auto, converted to manual. BMW E36 with 1jz-gte engine
kuntauasli
178
13
did u buy red bmw from ampang? I think the root cause of this problem is coming from custom made clutch housing..juz my 2cent.
munky
1,967
20
PJ
www.playboy.com
yes bro. U know the car? u mean the clutch housing that houses the clutch cover, clutch disk, etc ? as in this picture ?
munky
1,967
20
PJ
www.playboy.com
btw, i have solved the gear hard to engage when cold problem. Sekali the clutch pump rosak. Reverse gear maybe synchro kong so need to take it out to check.
Dear all sifus,
is the Petrol injector cleaner really useful to old car? any review from sifus?
is it recommend to use on 9 yrs car?
many thanks :)
