Engine and gearbox vibrate when passing through watery
May 10, 2022
45
Hi there.. im doing k24 swap into my civic fd about a month ago. im having few problem.
1. whistling sound near right front when high rev ( above 6500 rpm upward ) - suspect driveshaft bearing .
2. Engine and gearbox vibrate when passing through watery .
There is no problem of vibration if speeding the car on dry road.
You DIY-ed the swap? If not why not go back to the shop to fix it for you?
#1 is a bit hard to troubleshoot without hearing the sound
#2 maybe it's a ABS sensor issue?
condifent2022
45
tq for your kind response. till now my mechanic is trying to figure out what when wrong... and yet they still could'nt find any solution. i've change the tie rod end and also a set of FRONT LOWER ARM BUSH "BIG / "SMALL" , 2 pcs of stabilizer link.. and till now i could'nt run my car safely on wet condition. it will skid to the left or right if i run through
pile of water.
pile of water.
The ABS sensor?
Hi peeps,
i would like some reccomendations to a good shop that specialises in HID bulbs and potentially troubleshoot as well. Thank you in advance.
Dev
