Uneven fender gap after change absorber
monsh
157
18
518
Hi all,
i just changed my absorber all 4 for my corolla ae101.
the weird part is that before i change the absorbers, front part got around 1.5 fingers gap
behind around 1 finger gap.
after i change absorber(just to clarify, its new), the front driver side 0.5 finger and passenger side remain 1.5 fingers.
the behind driver side 0.5 finger and passenger side become 1.5 finger.
i was told its possibly the spring, but i wonder, how come before change no problem now problem come.
and someone told me camber and alignment setting must be done again but i went to tire shop they said that setting alignment and camber will not correct the ride height.
I don't want to spend my money on something that will not solve the problem, because i highly doubt its the spring.
what are the possibilities that could cause this? Please help guys. Now my front driver side daun pisang already torn because the tire hit it when going through wavy road and cornering.
kazukimy
638
372
1,563
KL/Pahang
devil-home.blogspot.com
something wrong with ur absorber, and the installation mayb nt correct...need to take out and check it whether issit install properly
and alignment and camber wont do anything to the height of the car
monsh
157
18
518
is it possible the spring is the problem? i oso suspect wrongfully installed.
i feel like taking out the whole absorber system and check back the code and make sure its the correct model and height and such. really pening kepala like hell edi.
i test my original absorber, 1 side no more dampening power, but still when it was installed, it wasn't unbalance.
that's y i highly doubt that the spring is the problem .
what can be the other factor other than the absorber?
YYC
1,833
939
Maybe you check against the absorber top mounting rubber if worn out too much would also affect height balance.
And, use measuring tape to measure your spring/absorber height for both side see whether there is any major difference.
monsh
157
18
518
problem solved. it was wrongly installed.
opened and experiment, found out spring was cut, so didnt follow actual top base.
after a few calculation, bla bla bla, put everything back in, now both part 1.5 fingers gap :)
HPC and MAM's first ever 4 Endurance race in Sepang will commence this June 12th 2011. This will be a private event sanctioned by the Motorsports Association of Malaysia (MAM) and allows for all race prepared cars old and new ranging from 1600cc, 1800cc and 2000cc.
If you you have yourself a Honda Civic EG for example, your...
