SWIFT BOT-"low Comp Head Build"
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
Great job there.....
virqai
206
393
1,563
superbly done...finishing better then factory...
Big thanks mate...:adore:
simply AMAZING!
:biggrin:
3++ or 4++ hp ni....very nice
hhhaaa...no la,just play2 only...:driver:
Naisss
:thrasher:
Sent from my GT-N7000 using Tapatalk 2
:top:
This is cool, superb skills :adore:
:top::bebored:
---------- Post added at 01:10 AM ---------- 6 hour anti-bump limit - Previous post was at 12:55 AM ----------
Update....:party:
Test valve leak before regrind...
Regrind valve..blow air at valve lips to check leak...no bubble..ok
Block...have some area x even surface no 2,3 sleeve..check using aluminium bloc and filler gap..
After resurface block done...
---------- Post added at 01:49 AM ---------- 6 hour anti-bump limit - Previous post was at 01:10 AM ----------
Head install to block...
Pics..before take out head...running Engine..at this temp, i take the reading for static comp...
This swift already BOT..but have some issue,then need to redo...here(old setup) comp test with 2 pieces metal gasket 0.5+0.5=1mm...
Some other work for this swift during install head work...delete heater pipe...
Make new air bleeding...(next time upgrade...must to custom this pipe for new place for termostart)
Cover timing chain Before &&& after...
Water jacket modified...(i don't want to trust the oil ring..if its failure so water will enter to chain cover and mix with oil)
So its better to separate the stopper..
---------- Post added at 02:43 AM ---------- 6 hour anti-bump limit - Previous post was at 01:49 AM ----------
Put back all the stuff...Here the BOT set when its come... so for next upgrade will change turbo,header,intercooller and pipe etc-etc..
to settle clearance issue...after head swap and with old engine tune,this car have test at sic and thanks to 'god' some of the big issue Heat and Boosting prob gone...:adore:
Here some Pics that's maybe swifter owner's want to see...inside timing chain...
Question and help needed..."Oil drain from turbo to oil sump Location"
this pics show where the oil drain plug locate...i think the best place for the drain plug is more upper then oil level,its will help oil to drain easy without need to blow the oil in sump...correct me if i'm wrong...
This is what i found inside all the intercooler pipe..
This is new place that i plan for next upgrade...how about thats..????:questionmark:
That all for now..till next upgrade....ADIOZ....:party::thrasher::rock::vroam:
madew
12
Cant wait to see the next upgrade... Hehehh
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
thanks for the documentary virqai, that is some major engineering work. it's tedious to document the process especially when working on a project, but actually having these pictures and captions and to be able to share with people who appreciate builds like us, it's priceless.
please continue to share the progress of this turboed swift. i'm very eager to see the results
kudos
l2s_turbo
1,068
154
3,163
Keep them coming bro, it's very useful to my project as well. Thanks.
<p><a href="http://www.zerotohundred.com/?attachment_id=53809" rel="attachment wp-att-53809"><img class="aligncenter size-medium wp-image-53809" src="http://www.zerotohundred.com/wp-content/uploads/2013/05/Dan-Davis-Collection-600x281.jpg" alt="" width="600" height="281" /></a></p>
<p>As much as modern cars go these days, sometimes it just doesn't cut it for some enthusiasts. To these blokes, a modern car like the Bugatti Veyron or the Pagani Huayra doesn't carry the same beauty and grandeur...
