sucide doors
5115
Nobody
5,952
2,254
haha...if u install suicide door,those chick no longer want to get in ur car,esp those with mini skirt!!!!
i_Ce
674
thnx sakuraguy , for the VERY indepth report about it..hahaha..as for 5115..getting chicks with mini skirts to use suicide doors, is the whole point my friend!!!haha, just kidding...
ModMaestro
317
PJ & Sandakan
There are a few complications with installing suicide doors, or reverse hinge.
If you drive a small car, you might have to move your fuel door to accomadate the hinges. Take a good look at the front hinges. You could probably get away with a set of smaller hinges if you have nothing on the door, or your doors are small and light.
It's a problem for sedans because of the wheel arches. There is only a small straight area where the hinge can be mounted, typically right above the arches. So you would probably have to make sure that your whole door can be supported by just 1 mounting pointing. It's infinitely easier if you are planning to do it on a coupe. This is because of the larger area, and all you have to do is migrate all the hinges to the other side.
Wiring also poses a challenge if you are planning to reverse hinge a sedan rear door.
Also, suicide doors nowadays don't open 180 degrees. They open more like normal doors. 180 degrees operation is possible, but you would also need to hinge the door as well as the body. A lot of trial and error.
putra4767
550
door
jeanloo said:
I tot u meant Lambor Door or Scissors Door. Just get to know what suicide door is. Suicide door is convenient for for you to commit suicide and jump out during high speed?
This is a cool explanation BRO..............:regular_smile:
gohkokeng
2,443
4
suicide door in the sense when your car flip and turtled in an accident, your door cannot be opened up, hence it is called suicide door.
alien
2,564
4
5,138
kuala lumpur
i think tat's vertical or scissors or lambo doors u're talkin about..
suicide is the one on the rolls royce phantom..
where the front open like a normal call while the rear doors open backwards..
actually, the suicide doors help u get off the vehicle more err.. "majestic"..
makes u look better than normal cars would..hehe..
coz u'd just go out like u're coming out of a small house..
u just walk out..
so dun worry bout gals in miniskirts..
hehehe..
ExceL
1,726
162
3,163
Ampang/KL
if you have a ride equipped with suicide doors, chicks will WANT to get in your car.
appologies to any woman I may have offended =P
kelvio
1,450
selangor
www.geocities.com
but suicide doors very dangerous 1 lor
example if u come out from the car,then a car from behind knock ur door the doof will close and it might knock on ur leg or some thing
and if ur car on fire u want to jump off the car,but u cannot cos u got the door blocking ur way,
thats y they call suicide doors
but chick with mini skirt going up a car with suicide doors can easily 'cau kwong' lol
cos no doors blocking the view
so u will have all the hamsapians waiting in front of the car hahahaa
ModMaestro
317
PJ & Sandakan
Daniel Lee said:
Lots of hassle to get rid of the B-pillar if wanna install suicide doors.
You don't have to remove the B pillars to make suicide doors. Lots' of conversion still has the B pillars. It is an easier, albeit less impressive, modification.
When ppl talked about interlocking suicide doors, they invariably think about the RX-8. That is actually not a good suicide door design because you can't open the rear without opening the front. Granted, it's supposed to be a coupe not a sedan.
Independent interlocking suicide doors can be done, but like Dan said a lot of hassle. You first have to make sure the door lines up perfectly. Then it's just rearranging the latches and locks. But they usually have one more set of latches and locks to the bottom of the car, or locking to the body of the car. This allows the doors to be open independent of each other.
i_Ce
674
alrite guys..so where can i actually do the suicide doors then? any recomendations?
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
mayb u can consult the mech that did scissor doors for our vip taikor david... i heard his flying optima scissor doors are custom made.... i guess the mech can do so with ur custom suicidal doors....
Sliced bread, the sound of lambs playing in the springtime meadows for the first time and the discovery of Penicillin, they’re about the only things that garnered more positive headlines than the new Audi TT 2-litre. Now we have the soft-top version, and so do the tuners.
There are bigger names on the map than Nothelle, which has carved its own niche since Rolf Nothelle set up shop in 1967 in Duisburg, but the company is well respected, slickly presented and they turned over the keys...
