Squeeking Sound!!!
netmask
276
Need your opinion guys,
Everytime when I press my clucth, I'll will hear a loud squeeking sound. It gets really irritating sometimes.:angry_smile: Does anybody had the same problem b4??? Or can anyone tell me what should be fixed..
Thanks.
Fluffy
3,870
>>klang<<
its the joint at the end of the clutch pedal...
no lubricant..so produce irritating noise.hehe
just need to apply sum oil at the joint..
netmask
276
izzit the joint from the inside pedal?? because the sound comes from the outside of the car...
xcheong
1,650
its most probably worn clutch cable.
replace it.
also check if ur clutch its too hard to step.
if its too hard, u might need to replace your clutch.
if u dun replace it, u will damage ur firewall and that's quite serious.
cuz the clutch cable run thru the firewall from ur pedal.
i experience it already. and its quite costly to repair.
netmask
276
replace it.
Thanks so much bro. I'll check the clutch cable. As I can remember never replace the clutch cable b4. Appreciate ur help. Also thanks to u Fluffy. Cheers :regular_smile:
I've 1 HKS 3037 turbo need repair, the bearing come out oredi.. any workshop is the most recommanded or anyone here can pm me if u're doing repair turbo service..
roughly how much if repair this kind of ball bearing turbo?
