any workshop repair ball bearing turbo
JERRY_VR4
1,343
14
JOHOR BAHRU
I've 1 HKS 3037 turbo need repair, the bearing come out oredi.. any workshop is the most recommanded or anyone here can pm me if u're doing repair turbo service..
roughly how much if repair this kind of ball bearing turbo?
JERRY_VR4
1,343
14
JOHOR BAHRU
ask Tong turbo...his contact num 0123822334:bawling:
ok will call tmr, thanks bro .. some of my frenz told me not worthy to repair , cos normally repair this kind of ball bearing turbo they using thailand stuff like garret or wad's things to put inside.. is it true? or i just buy a garret turbo is more better?:confused:
jinkl
4,624
376
3,183
try contact tong or sdf
i hope ur shafts n etc arent destroyed together, but i tink u will need a whole new CHRA , i guess the Garrett CHRA will do too , then reuse back all ur housings , and wheels
proPIPING
1,077
5
i agree with jinkl...atleast you can save some rm..
JERRY_VR4
1,343
14
JOHOR BAHRU
ask oredi , cost ard RM3k plus to complete repair whole thing's. after repair will being totally new turbo edi lor :banghead:
they told me will using back original stuff, & garret dun haf the spare parts. is that true? i thinking they will using garret thing to put inside 1 leh ..:confused:
jinkl
4,624
376
3,183
u cant put or take stuff from inside the ballbearing catridge for my knowledge , must change the whole catridge , thts the 3k for
proPIPING
1,077
5
garrett turbo but stamped with hks...that is all about hks turbo...:biggrin::biggrin:
The Marketplace Top Posts
Hi guys,
I want to make checklist for buying a used Proton.
What's do you guys recommend one should check/keep in mind when buying a used Proton/Used Car.
Here are few points from me which may or may not be correct so please correct if I am wrong.
1: Prefer to buy used car from owners instead of dealers.
2: Check engine blow back. If there is some then engine is weak.
3: Check exhaust fume color. If light blueish then engine burns engine oil.
4: Check engine bay for any...
