- Feb 23, 2006
- 396
- 2
- 1,518
mine is the 06 vios E with rear drum brake
now when my slowly press the brake before the car full stops, i hear weird noise on the rear (krak..krak ..krak ...like metal intermittently grinding with something)
after several test conditioned performed confirm only when braking got this sound and come from rear
went to 1st workshop:
1) use air gun clean the inside of drum -> result, still got noice but slighhtly lower
2) suspect drum bowl warped / bengkok, suggest me to chnge brake shoe 1st if can need to skim the drum bowl -->result , after change brake shoe sound even louder
since after chaning brake shoe, time very late and the shop ask me come back tomorrow to check again.
i went to 2nd workshop for 2nd opinion:
1) suggest to skim drum bowl -->result, 1 bowl is slightly dented , but still got sound there
2) skim the newly installed brake shoe --> same :x
3) furtehr check found 1 side the brake pump is leaking oil, suggest might be the issue --> pending stock to come tomorrow to change it
4) check the springs , absorber, stabilizer links ...all ok
anyone of u guys experience before? am not sure even after replacing the brake pump, ths issue will still be there or not
urgent help needed, car left at the workshop now !!
