Proton owners with coilovers
STR
155
4
18
Penang
wrong spring rate...
u need spring rate around 4-5k at front and 2.5~3k for rear....
problem solved
Okay, will keep that in mind. The rear coilovers already making some weird noise when im driving through bumps. Will look for that particular spring rate when im about service.
STR
155
4
18
Penang
I had my old front abs redone, means cut open, service/change and now is serviceable. Rear are hilo only. Then friend offered me his D2 coilover which he did not want anymore since his project car cancelled. Bought them cheap but even with softest setting still hard. Live with it for a few years already since the car nowadays rarely driven, but thinking of servicing my old set and change back......lol
So, if you install back the old abs, the rattling and stuffs wont be there anymore?Or is it something like, once they start to rattle, they gonna be there until you actually fix the real root cause?
Not sure, as have not done any reversal yet......lol
sanekit
Dec 9, 2015
1,616
157
663
is it like knock knock sound? if so then the valve inside problem dy. HWL is serviceable so u can send it for servicing and setup again.
sweelt
Nov 6, 2016
2,306
248
663
Penang
is it grooop groooop sound ? mine sound like that when go over bump.
is not bottom scratching btw.
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
kluk sound if heard from bottom is balljoint+lower arm bushing
if heard from top at front bonnet...mostly is suspension top mounting
  • Like
Reactions: STR
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
If from the rear, how to tell if it's top or bottom?
similar method... if sound u hear coming from lower back... its lower arm or trailing arm bush... if from top rear of your head...its top mount..
  • Like
Reactions: STR
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
sanekit
Dec 9, 2015
1,616
157
663
need to record this sound. haha. i also dunno how to type it. mine the valve inside they said makan dy. coz the alignment guy check the trailing arm bushes all still ok.
Do you guys know where i can do rivet nut installation on the chassis? Planning to include more mounting points on the chassis for stiffening bars.
something like the link below
Pelican Technical Article: Installing the Lower Cross Brace on Your BMW
