Proton owners with coilovers
STR
155
4
18
wrong spring rate...
u need spring rate around 4-5k at front and 2.5~3k for rear....
problem solved
Okay, will keep that in mind. The rear coilovers already making some weird noise when im driving through bumps. Will look for that particular spring rate when im about service.
STR
155
4
18
I had my old front abs redone, means cut open, service/change and now is serviceable. Rear are hilo only. Then friend offered me his D2 coilover which he did not want anymore since his project car cancelled. Bought them cheap but even with softest setting still hard. Live with it for a few years already since the car nowadays rarely driven, but thinking of servicing my old set and change back......lol
So, if you install back the old abs, the rattling and stuffs wont be there anymore?Or is it something like, once they start to rattle, they gonna be there until you actually fix the real root cause?
29,998
Not sure, as have not done any reversal yet......lol
sanekit
Dec 9, 2015
1,616
157
is it like knock knock sound? if so then the valve inside problem dy. HWL is serviceable so u can send it for servicing and setup again.
sweelt
Nov 6, 2016
2,306
248
is it grooop groooop sound ? mine sound like that when go over bump.
is not bottom scratching btw.
kluk sound if heard from bottom is balljoint+lower arm bushing
if heard from top at front bonnet...mostly is suspension top mounting
Reactions: STR
If from the rear, how to tell if it's top or bottom?
similar method... if sound u hear coming from lower back... its lower arm or trailing arm bush... if from top rear of your head...its top mount..
Reactions: STR
sanekit
Dec 9, 2015
1,616
157
need to record this sound. haha. i also dunno how to type it. mine the valve inside they said makan dy. coz the alignment guy check the trailing arm bushes all still ok.
Okay, this morning i wake up i just realise that my civic hatch, which is already 17 years old next year counted.
there is a small part of bubble( karat i think) starting to popped out, and i know that it will infect the others. so i call my mech la.. so he tell me, "to be honest la, i also told u already, if the body old liao, rust sure will appear.. den will got hole come out if more worst. if wan to fix leh, u grind it out, cover with wad... den wad... den spray... who knows, mayb half...
