Pls gif some advise to me in changing engine
DanzEterna
15,911
3,371
www.primeperdanaclub.com
just buy a halfcut & transplant the engine, halfcut rm5k++ + workmanship rm1.5k = total RM6-8k including
replacing wear & tear parts.
add on another 1-1.5k for cleaning up engine + spraying head + spraying engine bay.
but easier if using halfcut from pulsar since it was FWD/Awd....same as bluebird u11 which is FWD
if using RWD sr20 u might have trouble finding/fitting FWD gearbox later on.....
To add another RM2 to 3k for exhaust system and suspension to go with the added power....:biggrin:
LittleWhiteWagon
1,656
187
P.J
I have 1 nissan bluebird u11 in ori but I wanna to convert it to sr20det engine it is cost very high?or need to change many thing?pls gif some advise
You only can use FWD/AWD SR20's. The RWD's do not fit.
If you use the AWD one, you need to get a FWD gearbox to fit because the AWD gearbox cannot lock. There are big spline/small spline gearboxes, the differences you can use google and do a bit of research about it, I cannot remember all the gearbox codes.
Sifu, need help....
My ride is wira 4G13.:biggrin:
1) Wanna to upgrade rear drum brake to rear disc brake. Any suggestion, what contact, where to do it, cost range.:adore:
2) My ori brake disc already skim 3 & may be 4 times, can't remember liao. Now looks like need to skim again to get smooth surface. Should I direct go for new brake disc to get better grip during braking.
3) Brake caliper did service 1 time around 2yrs ago. Can I change it to 1600cc type of brake caliper. Is...
