How exactly can you get new Japan GAB now?from my opinion...find GAB fr Japan....u will satisfy....
GAB which available here im not sure....could be recond set......
No information on that.just wondering, issit the Gab SS is the same factory as Amprotech??? made in Taiwan..??
why jin?they look the same is it?just wondering, issit the Gab SS is the same factory as Amprotech??? made in Taiwan..??
yup, almost the same... even the color oso 100% same...why jin?they look the same is it?
Anyway, it's on promotion for Wira/Waja/Gen.2/Persona.yup, almost the same... even the color oso 100% same...
btw, if the SS is from the same factory, then that set of damper kit is damn good 1 loo....
I believe that it's a trade secret unless we cut open a strut and check on the inner diameter.what is the piston diameter of the SS series compare to others? i got to know the bigger diameter allows better damping. is it true?
I see. thanksI believe that it's a trade secret unless we cut open a strut and check on the inner diameter.
I went to kakimotor in sunway and the sales person recommend me the zerone adjustable claiming a bigger pistons for more precise damping, then i went to 1 utama shopping center and saw the pedders absorboers claming a 52 mm diameter pistons for better performance. So im just wondering and pop out this question.bigger piston can dissipate heat better too.bigger piston=better damping,it's true.
reason,forgot....hehehe...try google it up star scream.i've read the article before.
there a good reason why all adj sus manufacturer racing to make their piston
bigger.the biggest that i've heard of if i'm not mistaken is a round 48-52mm.
don't shoot me if i'm wrong.tend to forget a lot of car tech lately.hehehe.....
Totally agree. The material grade use on springs, shafts, housing & etc, Inverted monotube design & the most significant, production QC. Impurities in the gas/liquid filled chamber might also effect the overall performance.big doesn't mean it's good.sometimes the design that made the abs perform well.
there's other factor that need to take into consideration in making a good set of
abs.
hehehe......ciaklat jin...sick liow ar?i tot bigger piston gets bigger power... issin't it..??
not meh..?? last time when using 82mm piston, only gets 170whp... now using 91mm piston... gets 210whp ler....hehehe......ciaklat jin...sick liow ar?
