ok to knocking on low rpm?
1298
386
SABAH
www.irs-asia.com
xtremeleo, for what I know, "pinging" and "knocking" are more or less the same. Some with "tik tik tik" sound while some might have "tok tok tok" sound. Factory setting normally won't be in a optimum way but will make our engine run safe all the time, anytime.
To run with high ignition timing, fuel quality plays an important part. If you run your engine with, for example, methanol, then you will be fine to crank up more boost and advance the ignition timing.
However, there is no point to advance or retard the ignition timing if you are still using the stock ECU. It won't help much. Advance the timing, engine will knock during high RPM and will "boooom" anytime. Retard it, you won't have low rpm power. Unless you are using some kinda piggy back such as e-manage, or go standalone if budget allows.
Oh yea, 10 degree advance in ignition timing is kinda lot. You should be grateful your ECU is able to retard it automatically otherwise you might be busy looking for a new engine by now. Hahaa.
Cheers.
kweng84
2,245
6
PUCHONG
www.zerotohundred.com
if carb engine, can we tune the AFR until the fuel/air ratio ngam ngam that the knocking sound wont occured?? i tried with the tuning AFR and the knocking sound become less...so what actually causes the knocking sound? fuel too rich or too lean?
Doink
3,492
14
House
my cars all advanced timing for better pick up...so when low rpm i put more throttle the engine will have knocking...actually knocking is not good and a serious knocking can damage ur engine forever.slight knocking is usual for better performance...dont always drive with low rpm...at least maintain at 3k rpm.depends how u tune ur engine according to ur driving condition...
normality78
3,052
23
5,138
JB
fark... im getting more confuse.....
1 more question. saying we advanced our ignition timing off boost. abit link back to my cam thread that i posted, can we use adjustable cam pulley to do something about it?
xtremeleo
3,247
464
5,183
normality, i may be able to explain about ping / knock, but these infos will confuse u more if u havent mastered the fundamental theories. hmm.. maybe mastered is too strong a word, but u have to know the fundamentals bro.
1298 : u may be able to run if u can lower ur combustion temperature down, say wit a set of water injector system. the trick is to lower the combustion chamber down, before combustion takes place in its stroke so dat the temperature inside the combustion chamber is alwiz in check witin the limits of the engine's internals AND to prevent PRE-IGNITION dat will give out those ping / knock sound. RON numbers r actually to show how a particular fuel wit certain compositions can avoid ping / preignition in gasoline engines, so using a higher RON wud definitely be better for advancing d ignition timing. our country 97 RON is more then enuff compared to 88 RON dat is recommended for my ride to operate at its optimum.
advacing ignition timing in a std engine is alowable, witin its limit. 10 degree isnt much compared to sum guy dat hit 23~30 degree (estimated, as i heard VTEC ignition system may advance as much as 40 degree when VTEC is activated, have to reconfirm dis wit any VTEC sifu) on his VTEC, i can hear his engine ping-ed while i watched his mech tune his ride using an emanage. crazy wei, orang takmau kalah kot.
doink : if u r using a proton, and want power, u dont have a choice except to advance the timing, rite? just be careful wit the consiquences bro, engine rebuild isnt cheap :)
xtremeleo
3,247
464
5,183
kweng : ping / knock may occur out of lean afr (precombustion because lean mixture combustion emits large quantity of heat, too much and ur internals may melt), and overadvance ignition timing. just imagine dis, combustion compressed mixture of air and fuel gives out a lot of energy and heat. if u overadvance (keyword : overadvance, hence advancing is safe, as long as its witin the safety limit. outta the limit, and u r OVERadvancing the ignition limit) the ignition timing, the mixture may pre-ignite and combust before the actual power stroke is supposed to be at, BUT the piston is on the way up and wit the combustion process advanced too much, it is force to go down. wit two forces applied to the piston (dynamic way up, combustiom forces it to go downwards), it cant go nowhere but force its way up, since the other pistons and crankshaft assembly is forcing dis particular piston up. dis piston will rattle on its way to balance the forces applied to it, hence u have a vibrating piston, bearing, internals which may score ur block, fark ur bearings, etc.
BUT, just imagine.. if u combust a compressed mixture and creates a whole lot of energy, how much energy can u create if u compress a combusted mixture? u get me? d 2nd process will emit even higher energy and will push the pistons down faster then the first process, which will give u higher torque output.
p/s otai2 :sumone please correct me, i think sumthing r wrong in my post ler. iam too pening to re-check, sorry ya..
1298
386
SABAH
www.irs-asia.com
Ok, looks like things are getting more complicated...hahaha. Back to what the topic says, "ok to knocking on low rpm?", simple answer to it, a "NO". So, pinging or knocking won't occur if tuning is set right, doesn't matter if you are driving at low or high rpm.
Doink, to your statement, "slight knocking is usual for better performance...", that's a big no. Better head to different mech if yours is telling you that. ;)
normality78, cam position timing is to advance or retard the duration timing of air going in and out of the combustion camber. Nothing to do with ignition timing.
Cheers.
kweng84
2,245
6
PUCHONG
xtremeleo: well said ;) so, what is the best solution to avoid the overadvancing ignition timing?
xtremeleo
3,247
464
5,183
thanx, but personally they r gonna sumbody else dat can explain those better, trust me. sumtimes iam not good at posting words, my words may be better when iam talking in person as i will try my best to show what i mean ie wit diagram, motions, etc. enuff about me, *shy* lol
solutions? hmm.. first, maybe u may not overadvance (again, keyword : OVER) and stay witin the engine limitations. 2ndly, u may wanna use a higher RON fuel such as the Vpower, as i explained earlier, RON shows how well a particular fuel avoids knock / pre igniting and since Vpower is rated to have more then 97, hence the suggestion. and 3rd, u may wanna use a colder (comparatively to factory std ie 5 to 6, ur plugs will foul if too cold a plug is used) protruded plug (the tip is a bit longer, and plugs have "P" in their code) for the same effect as advancing ur engine timing, but not mess around wit the actual timing. get me?
xtremeleo
3,247
464
5,183
Cheers.
dat was i wanna emphasize, u shudnt tune dat slight knock / ping occurs and say its okie. but, when i asked joshua regarding dis, he said his 181 hp 4g91 iswara pings at lower revv as he set it up like dat, and he said it was okie. for me, iam not gonna do dat as i want my engine to last. wit dat being said, joshua's 4g91 hadnt any problem for about 5 years wit dat kinda tuning, and i havent seen his engine in any kinda problem except for regular maintenance and replacing wear and tear parts. dis is the part dat was puzzling me, because i can hear his engine pings slightly on lower revv, and the sound disappear on higher revv. as u can see, dat engine is making lots of power, and on dyno power came quite early and climbs to haeven fast!!
Joeker
Walking Dead
3,580
62
Jinjang
I think alot of you guys are confuse about the meaning of knocking, Preignition, Pinging, Detonation.
I give it a shot at explaining what they mean k?
Knocking and Detonation are smiliar. When knocking or detonation happens, it creates pinging sound (as described by an old ZTH sifu, Sleepwalker, "it soulds like small pebbles rattling inside a Coke can")
It is caused by abnormal combustion. Normal combustion produces smooth pressure, the flame sweeps smoothle across the combustion chamber.
Abnormal combustion is as when the explosion flames from the spark sweeps across, before it reaches the far side, another explosion occurs.
Over a long time, detonation or knocking will also cause preignition.
Preignition on the other hand is a situation where combustion occurs before spark plug fires.
When preginition happens, it produce a "thuk" (sounds abit like when you step hard on the concrete floor with you bare heel).
xtremeleo
3,247
464
5,183
there u go, a complete elaboration by on of the sifu himself!!! thanx a lot joeker, it wud be ebtter if u can explain stuffs like dis to us mewbie more often. hoho..
hello guys..
i already got e-manage..
but some people say..
chip wil incease more power n torque..
plzz state to me which is beter or put in both..?
plus izzit safe?
thanks..
