NA turbo car with knocking sound
tailgatepro
37
Singapore
my NA engine with turbo had knocking sound if top up 97, 95, 92 when toup in both SG/Malaysia.
But the knocking is gone if 98 or V power.
Is it the tuning for ignition timing wrong cause knocking?
my boost max 0.7 bar.
When boost reach 0.3 bar, knocking sound came.
No kocking for 98 and above fuel.
xtremeleo
3,247
464
5,183
protoevo, whaddaya mean by compression timing? ive never heard of dat one before, in my experience, u cant control compression
its the tuning, check dat up.. or ull feck ur engine seriously, i dont think it stops completely wit the vpower, its just u cant hear it. d vpower is still a ron97 wit different additives pack, and when ping / preignition depends on the ron of the fuel, i dont think its stopped completely by simply changing the fuel
SimpleGuy
751
Compression too high lead u to predetonate ur fuel cause u knocking, too davance timing also cause predetonate. Your case mostly compression too high, bcoz using v-power can save u from fuel burn too early. Change to a thicker head gasket will solve ^_^
catan
173
Png
You need to remap or retune your ignition map....
becoz your car was from NA to turbo and the ECU still used back? If yes u need to retune the ignition map.
Ignition map for NA and turbo engine are different.
Some thing like NA engine ignition will increase when RPM increase..
Turbo engine the Ignition will decrease when RPM increase, coz the turbine pumping too many air to the chamber and compression go high. Advance the firing will coz it get more knocking.
And the spark plug also is one of the reason. For turbo heat range is 8~9 ....
Pls Correct me if I'm wrong .....
alantan
3,573
15
kl
mebbe its a sign that you should remove your 'bolt on turbo' and leave the poor engine alone.
your type of knocking is probably due to 'abnormal combustion' in the internal parts of the engine. Its not the type of fuel in your case but the a/f mixture.
my guess is overide the stock ecu or remap it.which ever that fits your budget...
or simply just remove the BOT..your engine will not go far with it unless you have more money to buy replacement......'whichever that suit your budgets'
btw, what car is it?
xtremeleo
3,247
464
5,183
u shud give us more info on ur setting ie what management do u have, who tuned it up, what plugs grade r u using, any thicker gasket, etc.
93na
597
20
bro play na!!!! ha ha ha!!!! or buy a turbo engine! bot does not last long and will give u endless problem! had my putra bot along time ago... never do it again!
hi guyz... need ur help.. jz now i bought a set of small bulb from enous 1 utama... since i dono how to install so wanna ask da guy there to install but they say have to pay minimum of RM 10 for installation on any product except its stated free installation.. thinking it would be kinna easy job to DIY, don wan waste another RM 10 on it.. so guyz.. can show me how to DIY install small bulb in headlights for a wira? plz :D
