ok to knocking on low rpm?
normality78
3,052
23
5,138
JB
past weekened, drink teas with some drag runners back in JB. one of them mentioned its fine to have knocking on low rpm band but never on high rpm. how correct can he be?
Lopot
396
K.L
I thought knocking is not good to your car no matter what rpm it is.
normality78
3,052
23
5,138
JB
this is the reason why this thread was created. kekekeke
nitrus
2,895
35
1,648
Sorry noob question.. I also wanna know how exactly is "knocking" like ?
xtremeleo
3,247
464
5,183
alvikpck : dat isnt ALWIZ true, sum tuner set their engine up like dat to access the power quicker. i heard dat over advancing the ignition timing will do this, but on low rpm, the temp isnt as hot as in the higher revv range, so its considered okie.
but no matter what, when knock happens, there will be sum engine damage, even if they cant be detected. i wont allow dis to happen on my ride, no matter what
normality78
3,052
23
5,138
JB
yup. this si exactly wat he said
nitrus
2,895
35
1,648
So may i know what is engine knocking ? Is it some loud knocking sound or car knocking vibration kind ?
xtremeleo
3,247
464
5,183
theorekz : dat is true, and once u can hear it, its bad imo. on the road, u'll mostly hear dis sound on those mitsu / proton engines, which make quite an irritatin sound. krik krik krik, sumthing like dat. y dont u try dis urself, put on high gear and cruise wit super slow speed, dat usually creeps the sound i described out.
nitrus
2,895
35
1,648
Ohh... So knocking is the "krik krik krik" sound ? Ok k .. Phew...
1298
386
SABAH
www.irs-asia.com
For what I know, tuners don't set the ignition timing high up to the point where knocks will occur, but just lean out the air/fuel mixture a little bit so that the turbo will spool up faster.
Lean out the mixture in low rpm range is fine with accurate tuning but not make the engine knocks. It's totally different thing.
Cheers!
xtremeleo
3,247
464
5,183
1298 : i dont understand bro, so does this means dat knock and ping r two different things? ping usually is caused by overadvancing the ignition timing, and ive read sumwhere dat knock is the sound u hear when ping occurs, so i tot the two of them r the same thing, or at least caused by the same thing. guess i was wrong, ya
in charged engines, or at least in the one iam using, advancing the ignition timing in lower revv range wud give me better acceleration compared if i were to stay wit the factory setting. ignition timing in a charged engine is advanced during off boost, and retarded when boost kicks in, dats fundermental / logic. setting the afr lean at lower revv is okie, since, like the case of overadvancing ignition timing, the temp is considerably cool hence letting u set afr AND ignition timing as high as possibly, safely, means u shudnt let the engine knock (ping? iam a bit confused now, will confirm after reading more about dis)
in any case, my engine's std ecu wont let me to advance more den 10 degree, it will retard the ignition timing if i do advane more then dat. its sum kinda safety feature, safety indeed dat it wont let me have sum extra fun. hoho..
Hi guys, as topic states my coilovers need a rebuild. So far only place that rebuilds hypermax 2 that I've been able to find is Garage R in Singapore.
Suggestions?
