not use coolant...
apisanif
173
sri kembangan
my pomen said that if i use battery water in ur radiator is more better using water+coolant..is it true??anyone else using battery water??
Opel
136
Malacca
battery water= pure h20 as we learn in chemistry last time
normal pipe water....h20 with some mineral, dirt, clorine etc etc....
coolant, mixture of h20 with some organic properties for anti boiling purpose (increse the efficiency of h20 in water cooling system by increasing the boiling temp of water h20.
thus boiling temp of coolant + h20 = 1XXC
boling temp of pure h20 = 100C
see the difference?
acbc
4,615
KD
I used 80% coolant and 20% water. This help to reduce rusts (on 4G63 especially).
prodigy
2,786
apisanif,
Do you get the point raised by Opel? Very well explained indeed and that using battery water will only raise your engine temperature as its fails to cool down sufficiently. While i don't think your engine will blow if you ever decide to use battery water inside the radiator but certainly its too hot. Would you rather run your engine hot or slightly cooler?
The whole idea about using coolant is the ability to resist rust and most importantly increase the boiling point of water. Every car should use it. Also, a plus point about using coolant is that coolants normally come in very fancy colors ie. fluoroscent green, light blue, bright red and this is a very good leak indicator as compared to normal water because you might dismiss it as aircon water if there's leak.
apisanif
173
sri kembangan
i know that..just asking whether anyone had any problem b4..so im going to use back coolant water..cheers
Opel
136
Malacca
btw i found the scientific name for coolant 'propylene glycol'...lots of info can obtain from googling :)
Hope someone can trow some light. Want to upgrade cams and i think R3 cams are 268 degrees right? (correct me if wrong). Any significant diff between 268 and 272 cams?
AFter the cams, pulleys changed, do you need to change valve lifters and if there anything else?
Also since the siemens ecu cannot / hard to recalibrate, then after changing cams, how to adjust a/f mixture? SAFC can be used on siemens? any other piggy backs? Will R3 provide or sell the piggy back?
Also is it possible...
