- Feb 2, 2006
- 198
- 0
- 1,516
Hope someone can trow some light. Want to upgrade cams and i think R3 cams are 268 degrees right? (correct me if wrong). Any significant diff between 268 and 272 cams?
AFter the cams, pulleys changed, do you need to change valve lifters and if there anything else?
Also since the siemens ecu cannot / hard to recalibrate, then after changing cams, how to adjust a/f mixture? SAFC can be used on siemens? any other piggy backs? Will R3 provide or sell the piggy back?
Also is it possible to polish TB on your own with fine grade sand paper?
