Plan to get used Satria SE. What to take note?
kkchai
15
Hi everyone...
I am planning to get an used Satria SE since fit into budget <25k.
Any precaution or what to take note when looking at this used Proton car? Engine? Electronic? Interrior? Exterior?
Hope you all with experience could advise me as I don't want to get into financial meltdown because of used car...
Thanks in advance....
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
dont get wira se... get the older wira before year 2000 with mmc ecu....
arrowhead
4,621
152
5,163
Damansara/PJ
he meant satria bro.. hehe. all satria se's are equiped with the amazing, ever so awesome SIEMENS ecu.
and yeah, i think what gt_auto said is most important. check whether the car has been into a serious accident or not. cuz if it has, u will face some really annoying, unsolvable sounds, weird allignment issues... and it doesnt stop there.. good luck.
kkchai
15
Thanks for the advice.
Is Wira SE and Satria SE share same Siemen ECU? So advisable not to get Satria SE?
By the way, is the Siemen ECU bad? Like to understand why you don't recon it,,,
kkchai
15
What are common failures in this Proton car?
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
normal usage ok... no difference...
the difference is when u start to upgrade ur engine.... especially going for larger displacement, larger throttle body and larger injector.... u cannot use piggyback ecu such as safc and so on....
power window motor...
xin
626
try to make sure the car is as stock condition as possible. Look down on below the steering column... try to make sure the wirings are not messy. If not, next time need waste time to re-wire the wires neatly again.
Make sure everything/switches are working on the dashboard. The look at the engine compartment if there is any non-stock parts changed. This point can request for more nego hehe. And lastly like other forummers mentioned, look at the car condition/accidents/rustings.
If would be great if seller could provide records of previous services/repairs done.
Hello Bro's out there!!!
My car is jerking like crazy!!! What do u think? Other than spark plugs and throttle body what else could be causing the jerking? Help me guys!!!
