need help SUZUKI Kei 660 (turbo) Engine
momocultus
7
1,503
am looking for suzuki 660cc turbo charged 3cylinder,twin cam engine. engine code F6a (timing belt engine) or k6a (timing chain engine)
do you guys know any chop shop that may carry the above engine?
please call me or sms me if you have any info on these.. 0122472323 momo
momocultus
7
1,503
can see this type of engine mostly at chopshop
l
bro help me out let me know where can i find these engine.. i had tried so many places but couldnt source out infact based on a friend advise i went to kuching to source for these engine but couldnt.. help e out if you find one..
these engine are found in suzuki kei,alto works,cappucino etc
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
try to look at chopshop near pasar borong selayang...
i saw a few of this engine in good condition over there....
Hi all,
I just did a tranny swap on my car from auto to manual.
So far here's what i found out!
Things That you need:
1: Transmission
2: Drive Shafts (The Auto center drive shaft does is different from the Manual one buy a few MM
3: Gear lever
4: Pedals
5: Gear Box Mountings
6: clutch pump with all the hoses.
Well... the only problem i have is that the check engine light is on after the conversion. I know there is small modification required on the wiring to get rid of...
