Sifu has spokenYou'll need GTI or aftermarket absorbers also.
The GTI's ARB is mounted on the absorbers while the normal satria ones are mounted on the lower arm.
evo 1 arb is the same with GSR.. onli E2 & E3 have arb mounted to the absorber..Wow, thanks alot all sifus! Yup i only know GTi arb is mount on the absorbers instead but i have no idea on other items i need.
So the list is:
1) Absobers with arb mount/flange
2) Stab link
3) ARB from evo 1-3 (any other aftermarket ones which is thicker?)
4) Satay bush?
5)?
What about other bushes? Can use back ori satria front arb buses? U bush....? abit blurr on those hehe
Thx!
Mizi do u have pic of the ARB...dun have any idea what is the ARB...anyway is GTi suspension system same as 1.6 satria suspension system?Sifu has spokenGTi ones are mounted on the absorbers. Evo 1-3 ARB will fit in GTi but not GSR or normal satria as it is mounted on the lower arm. Even after you have the ARB, you'll need the stab link to connect your ARB to your absorbers.
oic now i know ARB stand for anti roll bar huhuhuoem absobers.. KYB should cost less than 200 a piece. bought mine for 130. long time ago.
Stab link should cost RM 50 below for taiwans.. slightly more for OEM proton.
Ori Evo's are mucho expensive. The difference is.. which one will last longer. Has one taiwanese one.. the whole thing broke at the hinge and totally dropped off while i was connering..
ARB.. thickest would be those UR abrs.. 20mm i think. No idea how much.. Ori is.. 16 mm.. i think
Bush.. super pro .. less than RM 100, 2 piece. I have if u want. PM me
Thats all you need... U may want to add in sgti spring to go with your absorbers. They are slightly harder.
If mounted properly.. then nice and slightly hard. If not.. you will be hearing lots of "bunyi tikus" very soft .. but audible.. makes u think like u got small BOV.
While you are on it.. perhaps u may want to consider changing your crossmember to evo's.
Thread starter | Similar threads | Forum | Replies | Date |
R | Perodua Viva Original condition recommended modification | Car Modification | 7 | |
U | Wira SE modification tips? | Car Modification | 13 | |
Alza engine transplant/major modification-mpv fr trackday | Car Modification | 25 | |
C | Satria Gti model Brake mod | Car Modification | 26 | |
M | Toyota CT15B Turbo fast spooling mod | Car Modification | 10 |
