Satria Gti model Brake mod
coolman91
coolman91
224
Hi,
Newbie here.....
wanted to ask can Satria GTI old satria model brake modification.....
Can R32 skyline brake caliper front 4 pot and rear 2 pot(with drum) able to mod into it ?
or any suggestion sifu
15,344
6,401
Hi,
Newbie here.....
Can. Just need to check whether it'll clear your rims. You'll need to add a custom fitted bracket. Then there's the rotors that'll work with the calipers. Did you upgrade the servo?
What size rims are you using?
coolman91
coolman91
224
Do u know where can do it ??
Now 15inch....
planing to go 17inch
or
15,344
6,401
Now 15inch....
or
Dude... Your car is a Satria right? Please do some research before you go and simply buy the wrong things. Satria is PCD4 x 100. None of those rims suite you.
And where do you stay? What is your budget for this modification? Do you know any mechanics?
  • Like
Reactions: lsm1991
Beyond 20,000 RPM!
Beyond 20,000 RPM!
29,878
8,347
Normal rims have, like mine is 4 x 100 plus 4 x 114.3. 8 holes type. But remember, going 17" probably need to use 40 series tyre , not too broad 45 series, but if using bigger diameter, with no engine mod, will zap some power.......
lsm1991
lsm1991
1,456
182
PJ
Sadddd...... hope to know where can modify
long as got moneys, theres quite a few places... rear conversion, i think easier to sumbat on proton disks
1)why are you going for this project... bling or function?
2)why r32 brakes? do you already have them or something?
3)back to one, if its bling ill just say go for brembo terus, get adapters to fit the caliper and upgrade the pump. If its function. actually evo3 brake setup works quite well on satrias
marsha1l_v6
marsha1l_v6
666
130
543
talking about mod, mcm2 boleh buat. Make sure you know what you want.
Let me share abit on changing brake set.
1) what is your preferred hub pcd.?
- my car comes with 4x114.3 pcd, but i convert it to 5x114.3 since theres many choice of rim available at that pcd.
2)what caliper/brake do you want?
- determine your rim
3) what kind of rim do you need?
- based on your caliper/rotor spec, choose the suitable rim
4)What is your rim jj ?
- once you know your spec rim (offset/size), choose proper width to suite your preferred tyre rubber spec and wheel arc fitment
thats one of the way for me to decide my mod initially. just my 2 cent
  • Like
Reactions: Izso
Beyond 20,000 RPM!
Beyond 20,000 RPM!
29,878
8,347
Yah, mine also all transfer from half cut, plug and play using same car brand.....
coolman91
coolman91
224
I know what u mean....
since my R32 brake kit already is 5x114.3 so i find for the rim 5x114.3
coolman91
coolman91
224
Power dont worry.... already more than enough that y looking for brake.
which i brought the R32 brake kit
  • Like
Reactions: vr2turbo
coolman91
coolman91
224
Who also got money i believe just the matter of time and saving.... ofcause i am looking for idea to cut short letting poeple Cut Throat.
1) function and weekend car
2) i saw people mod before but i lost the contact....
3) i think of EVO 7-9 brembo set but too exp it cost rotor and caliper front and rear RM3000-3500, with R32 RM1k only and same 4pot and 2pot for rear
coolman91
coolman91
224
1) 5x114.3 as there is alot nice JAPAN rim with that lug.
2) since u brought R32 brake kit, i checked its required 17inch for clearence
3) Since the rotor of the brake kit is 300mm below 17inch should be enough....
4) offset is the question i dont know how to calculate can teach me ....
Beyond 20,000 RPM!
Beyond 20,000 RPM!
29,878
8,347
Offset number are in mm. Normally many OEM offset is around +55 to +45, so say your original is +45 an using +35 offset this rim comes out further 10mm.
Not only offset you have to see the rim design too. If the spokes are on the outer edge then should be okay, some design the spokes are near the middle then even with lower number offset may not clear......
lsm1991
lsm1991
1,456
182
PJ
icic, so you already have the brake kit, that case then year you are pretty much stuck with those. was going to suggest just going evo3 since those are almost direct pnp... now the trouble you have, is it an issue with not being able to find someone to make the adapters? or do you literally not have anyone who can install them mechanism and all? former i can ask around, latter i think none of the fellas i know really wants to do this kind of swap
haha and the evo/subi/typer brembos cost 3k cause they huge and have relatively huge pistons compared to the 32.
minibeany
minibeany
559
82
28
17 inch rim might affect your turning radius. Make sure u have a real low profile tyres. I read some actually do a bit of roll fender to get more clearance.
  • Like
Reactions: sweelt
coolman91
coolman91
224
Thanks for the info...... still getting more knowledge about it hahha
coolman91
coolman91
224
thanks bro...... but maybe when i need i give u a PM
now recovering xD
Yes i know brembos are better and bigger but way higher cost already hahahaha
coolman91
coolman91
224
Hmmmm...... turning radius why will be affected ?? mind to give somemore advise. ty
fender already roll hahaha thanks for this advise =)
coolman91
coolman91
224
i think you can make do with 16"..iinm r32 stock wheel are 16"..300mm rotor would be nice for 16"
I scare later purchase a 16inch rim and clearance have issue best go 17 i guessss.....
furthermore 17inch tyres more selections right? hahaha
plan for zentino tyre semi slick
lsm1991
lsm1991
1,456
182
PJ
what do u mean by sure to hit ?
meaning offset number higher i will have issue when turning ??
basically theres 2 clearances to take care off
1)radius this refers to the top and bottom clearance, by right marshal is telling you 16" should be fine here since the skylines came with 16's factory
2)the offset/spoke refering to the left or right clearance (where the caliper may hit the rim's spoke at its side. this one, pandai pandailah.... nothing to do with the rim size, just the offset+spoke design
Beyond 20,000 RPM!
Beyond 20,000 RPM!
29,878
8,347
That quote was on the roll fender, meaning with 17" with higher profile tyres, and low offset number, the rims come out further will hit the fender
