yesterday send to mechanic to check up and i don't noe wat the hell he did now can tarik until 180 already...
all the sifu's..... can teach me wat else to mod ar ?
That means mivec gear ratio is like that izzit ?if u can hit 180 km/h with 5500 rpm on 5th gear it's mean yur mivec gearbox doesn't have any problem with the gear ratio...
My engine need to run in..... wat ?seem like ur engine still need to run in.....
the gear ratio between mivec and other 4G92/4G93 doesn`t have much different...That means mivec gear ratio is like that izzit ?
u better send ur car to a reputable mechanic to check...maybe ecu problem or mechanical...nothing to do v ur ratioAll the sifu i hav another problem...
When im ideling i rev 3 times and it cut off at 6500rpm... after the cut off then is back to 8500rpm cut off...
Can all the sifu tell me wat is wrong ?
Maybe bcuz i cannot reach 180 is bcuz of this problem...
u can change gear ratio by changing the final drive inside the gearbox. not by changing intel chipset...
