lighten crank pulley (alloy)
ashyu90
222
7
518
whether lighten crank pulley (alloy) is a much help in improving the performance of the engine???? :hmmmm:
there are many differences from the oem crank pulley???
hachiroku clan
633
73
its lighter so it gives your engine faster response and it unleashes a few hp.. but sifu's from here can help u out more i guess..
amrancharger
779
96
read somewhere that without the dampener in stock crank pulley, it will shorten the life of the engine...
i wonder how far is the truth in it... :hmmmm:
amrancharger
779
96
LCP(Lighten Crank Pulley) shud give u more pick up due to the lighten characteristic.
wat i read is dat...smaller/underdrive pulley will sacrifice your top speed plus burden the car electrical system but gives u the biggest gain in terms of butt dyno...coz it shud be very small and light...
if u wanna use LCP, try to get LCP that is OE size.
other than the pick up...i dun see any significant of using this LCP...
btw...i m using one in P.Myvi...well its a small cc car and manual...just felt the car revs very quickly/eagerly...and my butt dyno says i does increase the pick up...but i never got the chance to try top speed as i dare not push the pedal anymore...uhuhuhu!
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
my opinion....
to keep thing in balance when we change lighten crank pulley...change into lighten flywheel also...
:driver:
amrancharger
779
96
if we do lighten the flywheel also...wouldn't it affect the car ability on hilly roads...
heard dat cars with lighten flywheel will have less power to climb hilly/steep roads...
my fren with lighten flywheel broke his car clutch plate if not mistaken when trying to overtake cars on genting road as he just use third gear all the way in order to overtake..ahahaha...
Viera Sasaki
58
7
508
Perlis,Malaysia
From my experience using the lighten flywheel, it does decrease the torque and it became worst when going uphill. But it does increase the throttle response a lot.
93na
597
20
you will feel lighter and more responsive, i am using works wan now on my 1.8 its help together with cam pulley and better clutch.. he he he.............
amrancharger
779
96
hi there...
i have a few doubt on works LCP...
coz read in the advertisement...it is smaller size than OE.
so want to know yr feedback how was the top speed afterward?
tq in advance... :adore:
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
under-drive pulley.....
reduce the power steering load, alternator load, A/C compressor load from engine rotation....
means engine can turn easier (and might release a bit of missing power)......
but downside.....battery charging only happens at higher rpm than std..not good for those who always stuck in jamm.....and a/c oso not really cold during idle...coz the rotation of those a/c and alternator was reduced....steering might become heavy at slow speed oso :adore:
how it change the result i didn;t really know....u need to test wether to check if u like it or not... :adore:
ashyu90
222
7
518
i have a problem here...i have using LCP since 2 or 3 years ago...no problem with my engine...but now, when i do majot modification n get more power...i have problem...last 2 weeks...i "tarik" my car until rpm 9k...something bad has happen...my crank pulley was broken..crank angle crash...damn...now i use oem crank pulley...pomen said...better safe to use oem because there are have rubber that can absorb the vibration.....
