Installing Water Temp gauge
RB26
GoKart Lover
130
76
5,028
selayang
www.mangoesteen.net
Hi fellow ZTHian, i have currently bought a water temp meter, but no idea on the wiring part,hope sifu can show me some guide:
I have the sensor install and go thru firewall
red, black, white n yellow wire
have check the under neadth of the dashboard, not sure how to tarik the wiring for 12V? can i sambung from the fusebox? how? :stars:
mines998
1,048
149
663
Red should be 12v
Black should be Ground
Yellow & white is sensor
If sensor already fix just tap 12v from keys. Normally 12v wire is red colour.
u can tap from fuse that labelled as "clock" oso...since clock working only when ignition switched on....check the position by reffering to the fuse cover....anything that work when u switched on the ignition would do the same job....
RB26
GoKart Lover
130
76
5,028
selayang
www.mangoesteen.net
thanks, manage to get it work:
but i not able to find the lamp light, so day time and night time same light :hmmmm:, do you know where can get the lamp wire? is it Radio and cigratte light there got this wire?
ciggarate lighter port got light bulb/socket behind it....if u lazy to open dashboard center panel..then u try look for RH/LH light fuse socket at fusebox in the engine bay....
Show: 2007 Tokyo Motor Show (TMS), Lead actor : Nissan GT-R, Nickname : Godzilla.
The big Japanese supercar clash at the TMS that we’ve all been waiting for has been blown off course.
On one level, this month’s TMS was supposed to be a high stakes poker game between the Nissan "Godzilla" GT-R, Lexus LF-A, and Acura’s next interpretation of the NSX.
The GT-R is still on track. Emerging from the tightest...
