Installing Water Temp gauge
RB26
GoKart Lover
130
76
5,028
selayang
www.mangoesteen.net
Hi fellow ZTHian, i have currently bought a water temp meter, but no idea on the wiring part,hope sifu can show me some guide:
I have the sensor install and go thru firewall
red, black, white n yellow wire
have check the under neadth of the dashboard, not sure how to tarik the wiring for 12V? can i sambung from the fusebox? how? :stars:
mines998
1,048
149
663
Red should be 12v
Black should be Ground
Yellow & white is sensor
If sensor already fix just tap 12v from keys. Normally 12v wire is red colour.
u can tap from fuse that labelled as "clock" oso...since clock working only when ignition switched on....check the position by reffering to the fuse cover....anything that work when u switched on the ignition would do the same job....
RB26
GoKart Lover
130
76
5,028
selayang
www.mangoesteen.net
thanks, manage to get it work:
but i not able to find the lamp light, so day time and night time same light :hmmmm:, do you know where can get the lamp wire? is it Radio and cigratte light there got this wire?
ciggarate lighter port got light bulb/socket behind it....if u lazy to open dashboard center panel..then u try look for RH/LH light fuse socket at fusebox in the engine bay....
Anyone know what is the problem if a car won't crank up? My Civic '96 EFi (Manual) can't start at times. When I insert the key and crank it up, it will not crank. It just go.. "karak".. and nothing happened. I can still on my aircond and lock my car (central locking) which means battery still working right?
Anyone had the same problem? OR anyone know what can be the problem?
