IK20 or IK22
meg_omen
421
96
3,028
Home - Klang; O
heat will increase during compression, so if increase compression the amount of heat generated in the combustion chamber increases thus increase the chances of detonation. this heat will cause pre-ignition(actual term) where spark produce not by the plug itself.
few options to play:-
- plug heat range, up 1 point... still depending on the ratio increase
- add more fuel... can cool down the chamber abit
- fuel ron... if normally using ron95 then try ron97 otherwise need to add octane booster
- increase IG timing... to compensate the actual spark against spark created by the compression process
roughly that explain it... good luck...:proud:
coz all this can be google up... if you're into technical, browse the forum...
GoFastNews.com - All Racing News All the Time! - The Front Page
sorry... should have write 're-tune' instead...
fuh, one of the reason I seldom contribute to people questions...:stupid:
pcmoddingmy
1,147
101
www.pcmoddingmy.com
Haha... no worries bro. We are all in the same league here. :biggrin:
ahaw
141
6
reviving old thread;
between ik 20 and ik22, + normal ecu;
a) no tuning to ignition timing?
b) only feel up to 'kaki'?
appreciate sifu's feedback
Kind Regards,
Kind Regards,
20 equivalent to 6 heat range, 22 is 7 which is colder. What heat range do you require?
ahaw
141
6
Dear Sifo's;
Its heat range 6 = bkr6eix
and the most important info;
How to check, the NGK igniter OEM or counterfeit product?
Kind regards
To all the sifu out there....I need some suggestion, I have 2 engines on my mind now...either 4G91 DOHC or 1.6 V6 for my saga...
I need some comments and advice on which engine is better in performance and which engine is more reliable....
Can all the sifu give me some comments cause I really dont know which 1 is better...
