IK20 or IK22
meg_omen
421
96
3,028
Home - Klang; O
heat will increase during compression, so if increase compression the amount of heat generated in the combustion chamber increases thus increase the chances of detonation. this heat will cause pre-ignition(actual term) where spark produce not by the plug itself.
few options to play:-
- plug heat range, up 1 point... still depending on the ratio increase
- add more fuel... can cool down the chamber abit
- fuel ron... if normally using ron95 then try ron97 otherwise need to add octane booster
- increase IG timing... to compensate the actual spark against spark created by the compression process
roughly that explain it... good luck...:proud:
coz all this can be google up... if you're into technical, browse the forum...
GoFastNews.com - All Racing News All the Time! - The Front Page
sorry... should have write 're-tune' instead...
fuh, one of the reason I seldom contribute to people questions...:stupid:
pcmoddingmy
1,147
101
www.pcmoddingmy.com
Haha... no worries bro. We are all in the same league here. :biggrin:
ahaw
141
6
reviving old thread;
between ik 20 and ik22, + normal ecu;
a) no tuning to ignition timing?
b) only feel up to 'kaki'?
appreciate sifu's feedback
Kind Regards,
Kind Regards,
20 equivalent to 6 heat range, 22 is 7 which is colder. What heat range do you require?
ahaw
141
6
Dear Sifo's;
Its heat range 6 = bkr6eix
and the most important info;
How to check, the NGK igniter OEM or counterfeit product?
Kind regards
The Marketplace Top Posts
Step 1 – Remove the side mirror
Unclip the mirror gently by pulling at the bottom of the mirror. It should snap out once enough force is use. Don’t yank it too hard though.
Removing the side mirrors
Using a heatgun, warm the plastic that holds...
